09-29-2017
06:03
20:15
DavideFitbit
09-29-2017
06:03
20:15
DavideFitbit
Hi, got my Ionic today, used 1/2 hour for update and installing, and now getting this? version is 25.16.7
Moderator edit: format
Best Answer09-29-2017 06:38
09-29-2017 06:38
Yep, you need to update it, like we all have.
Best Answer09-29-2017 07:40
09-29-2017 07:40
I am having the same issue. I try to update and it says firmware is updated! Now what?
Best Answer09-29-2017 07:47
09-29-2017 07:47
Yeah, Fitbit rolled out a Firmware upgrade yesterday, My Ionic now has version 27.25.16.7
Gunny | Richmond, VA (USA)
Ionic Adidas Edition, Versa Special Edition, Aria 2 & Flyer | iPhone & Windows 10
Take a look at the Fitbit Help site for further Assistance & Information.
Best Answer09-29-2017 07:52
09-29-2017 07:52
Best Answer09-29-2017 08:23
09-29-2017 08:23
I setup my Ionic's Device Lock on day one. So, I just went to Device Lock again, to see what you are seeing. YES, I can confirm that I am receiving sorta the same thing, When I attempted to make a change I received the "BLUETOOTH Timed OUT" error! So it appears, the Device Lock function is NOT working with the new firmware update and whatever Device Lock was setup prior is still in effect on the Ionic.
Not a game stopper, but needs attention..
Best Answer09-29-2017 08:37
09-29-2017 08:37
@GySgt_Seidell wrote:So it appears, the Device Lock function is NOT working with the new firmware update and whatever Device Lock was setup prior is still in effect on the Ionic.
On mine, rocking 27.30.2.8, Device Lock is working. I’ve set a code on the phone app and it registered with my Ionic. First use of Ionic then needed the code to unlock.
Best Answer09-29-2017 08:46
09-29-2017 08:46
My firmware is 25.27.16.7. I’m located in the USA. It appears you have a more advanced firmware, where are you located?
Best Answer09-29-2017 08:48
09-29-2017 08:48
UK.
