10-20-2017 07:18
10-20-2017 07:18
I bought a brand new ionic yesterday, and I haven't had any chance to use it because initially it was stuck in a boot loop. A hardware reboot got out of the boot loop, but now the watch is stuck on a intial firmware update.
If any developers can help me with this issue, I haven't even had a chance to use the watch yet! 24 hours and still stuck in the setup process. Here is a detailed breakdown of the process as I see it:
Before a setup attempt:
My attempted setup:
Guidance on forcing the firmware through or basically anything for this £300 paperweight so I can actually use if for the first time would be amazing
Thanks
10-20-2017 07:59 - edited 10-20-2017 08:01
Hi
As restarting.. doesn't do the magic, fastest to exchange at the store of purchase with receipt.
Possible the phone number is on the receipt so you are able to call them (when desired), and they could set aside a fitbit ionic to exchange (if they do that).. (in case there's a few left in stock)..
11-26-2017 11:36 - edited 11-26-2017 11:37
Did you get anywhere with this? I am having the exact same trouble. New on Friday. Cannot update tracker hangs at about 80%, tells me WiFi is not on, it is, then says try Bluetooth, nothing happens. Think I may just take it back and get money back. Disappointed is not the word!
11-28-2017 07:09
11-28-2017 07:09
Same problem here. Bought the ionic today, took forever finding a way to get Wi-Fi connected (all the on/offs, through mobile, xbox and finally laptop that worked). Now im stuck at update. It has been three hours!! The bar on the app and the phone filled up, now its just the rectangular dot thing symbol on both...
11-28-2017 11:13
11-28-2017 11:13
Took mine back. Too many problems with this tracker judging from posts. Not worth the hassle. Will wait til all the issues are sorted, if at all.
12-05-2017 08:34
12-05-2017 08:34
I am stuck at 5% as well cant do any thing its a paper weight at this point..
Best Answer12-05-2017 10:59 - edited 12-05-2017 10:59
Firmware stuck 30 mins no movement here ... this is horrible!
Should i restart phone? or is that asking for more trouble?
12-06-2017 02:03
12-06-2017 02:03
As I really wanted this to work, I got my original replaced. Used hours to try to get the first one working, including 90 minutes in chat with fitbit, but to no use. Returned it and got a new one, it got the first update in 30 minutes, and I was then able to actually use the watch.
Im still not happy though. It works fine, seems to log my activites and sleep nicely, but it is slooooow in syncing. Now there is a new update out, and surprise surprise, same thing happens with my new watch. At least I am able to use it without the new update, but not sure how long I'm going to bother if this keeps up.
01-01-2018 12:46
01-01-2018 12:46
Same problem here, first time Fitbit Ionic stuck on firmware update? It says "hold tight this can take 5 - 10 minutes" but so far it's 45 minutes and still seems to be updating (not sure if it's actually updating).
FYI: I'm updating via desktop computer with Cox Cable fast internet.
01-01-2018 13:10
01-01-2018 13:10
@Mbjo wrote:Same problem here. Bought the ionic today, took forever finding a way to get Wi-Fi connected (all the on/offs, through mobile, xbox and finally laptop that worked). Now im stuck at update. It has been three hours!! The bar on the app and the phone filled up, now its just the rectangular dot thing symbol on both...
Just a tip that may help with the update: put it on the charger and then plug the charger into a computer. When mine installed the update, mine took hours too but it picked up as soon as I plugged it into the computer.
one cruise ship at a time!01-01-2018 14:28
01-01-2018 14:28
I started the update on a computer with the fitbit connected to a USB port. That computer also has high speed Internet and it's still taking hours to update. I have been using Fitbit products since my first Fitbit One and Charge 2, this model does not seem to be "ready for prime time".
01-04-2018 11:20
01-04-2018 11:20
This is exactly what happened to me, I switched off my phone for a few mins and then switched it back on and the set up was complete and Fitbit working fine.
01-04-2018 17:00
01-04-2018 17:00
Thanks! I did a full reset and started over. It's ok now.
Best Answer01-12-2018 12:18
01-12-2018 12:18
so after the blue screen filled up on your ionic, nothing happen? Mine had been an hour now and it's only on 1/10 of the screen
Best Answer01-12-2018 13:38
01-12-2018 13:38
04-12-2018 08:10
04-12-2018 08:10
I was updating the software for my Ionic’s fit bit and it chocked. So all I did was plug it into the computer hold down the left button and just held it down and it cleared it wasn’t really that difficult just got to be a bit patient. I also am doing the update for the software with it plugged into the computer it seems to be doing better when you have it plugged into the computer while downloading the new software.
08:11
10:40
04-15-2018
08:11
10:40
@26Dolly Welcome to the Fitbit family! Thanks for sharing your experience and the workaround that helped you out with this. I'm glad the updates went smoothly for you.
I'm sure your post will be helpful for other users who might be experiencing difficulties with the update. Thanks for sharing that Ionic updated better when plugged in. Something that helps with updates is having Ionic connected to Wi-Fi; specifically to a home network. Having it close to the router is also a good idea.
Thanks for sharing. See you around! ![]()
05-05-2018 14:39
05-05-2018 14:39
I'm so disappointed with the Ionic. I've used it for a few months but a couple days ago it stopped working....seemed to freeze at 1:30 pm on a day. I've spent most of a day chatting with Fitbit on efforts to reboot (and evidently upgrade to software) all to no avail. I got an email from support telling me the press three button/vibrate approach. Nada! I've gotten so far as to get to the upgrade (after installing bluetooth and wifi numerous times) but it never gets past 5% before timing out. I have it on top of my router and plugged into the computer. Fitbit support told be to make a video of my efforts! I guess they don't believe me. I bought on Amazon and it's too late for a return. You'd think Fitbit would offer a replacement. I'm out $240....I bought it to keep track of my lap swimming so I'll go back to looking at the clock. This is the 4th Fitbit product I've had and each has stopped working. Fool me once I guess....
05-05-2018 15:28
05-05-2018 15:28
Best Answer05-05-2018 20:19
05-05-2018 20:19
