03-16-2018 03:15
03-16-2018 03:15
I had connected my watch to my phone, notifications enabled, ready to go. I call my self and I realised a problem, the calling animations was not right. When it called it did not have the usual end call and answer call symbols on the fit bit. Rather it only had incoming call and the caller id. That was all there was on the screen. I know, from previous reviews and examples, e.g. the fitbit app its self. They showed us how the calling animation is meant to look. In my case it was different, it did not have the answer and end call symbols. Please someone help as I want to know what is wrong and how can I fix it?
Best Answer03-16-2018 05:20
03-16-2018 05:20
If you are using an android device, you will only see who is calling and the incoming call.
If you use an iphone, you will see the options to answer or reject the call from your ionic.
Are you receiving the call notification from an iphone?
