01-06-2019 12:06 - edited 01-06-2019 12:07
Hi Fitbitters
I have an Ionic and was using Skullcandy Smokin Buds 2 wireless earphones, everything works fine, pairing, volume control and Track change
I need to change them as they keep dropping out when running
Can anyone advise as to what i could get. I bought Jabra Elite Active 65t but neither volume control or track change worked.
I just need a pair that all those things work and will stay put during run. Cost is not important
Thanks
Best Answer01-06-2019 16:42
01-06-2019 16:42
I have the Fitbit Flyers, but I dont run so dont know how they'd be. But they work really well with the Ionic.
Helen | Western Australia
01-06-2019 17:00
01-06-2019 17:00
@SunsetRunner Have you considered the Fitbit Flyer earbuds? https://www.fitbit.com/shop/flyer
They work well, although also there ppl have reported dropping out issues. I never have this, though. They are not truly wire-free as there is a short wire connecting the two earbuds. You can control volume and track from the earbuds, although I rarely do this as it is much easier to do this from the tracker. I think they are great, but not the cheapest for sure!
