02-24-2019
21:45
06:29
SantiR
02-24-2019
21:45
06:29
SantiR
On a Fitbit help page (what has changed in the latest Fitbit update) it says the Ionic is on Fitbit os 27.something while the Versa is on 3.something. Is this just Fitbit not updating their website or is the Ionic no longer being updated?
Moderator Edit: Updated Subject for Clarity
02-25-2019 06:15
02-25-2019 06:15
The Ionic is still being updated. The versioning for Ionic starts with 27 the Versa starts with 32. Usually versions get referred to as the numbers after the 27/32 (33.1.30) which should be consistent on the two devices.
02-25-2019 06:15
02-25-2019 06:15
02-25-2019 06:28
02-25-2019 06:28
@SunsetRunner I hope you're doing well! Thanks for taking the time to post the inquiry about the versions of Fitbit watches.
In this case, the latest version for Fitbit watches should be the following:
Those are the updated versions you should see. Check this article for more details on the versions. If you see the number for a previous version; please try these update steps to sort this out.
@sfringer Thanks for sharing your help on this thread!
Hope this helps. Keep me posted!
