06-05-2018 17:23
06-05-2018 17:23
I saw this topic on a previous firmware issue. I am currently using 32.10.15 and the display will not show above 50%. I've had it on for several hours and it has not decreased but the fitbit app shows the battery is not full. Anyone have a fix?
Best Answer06-05-2018 21:43
06-05-2018 21:43
Have you tried restarting the Ionic several times? IF not, give that a try and see if it performs better. If that doesn't fix it, try a factory reset (on the Ionic, settings app, scroll to About). iF that fails then you will need to contact Support (link in my signature)
Helen | Western Australia
06-07-2018 06:18
06-07-2018 06:18
Welcome to the Forums @kenk85!
Thanks for bringing this to our attention, in addition to the great troubleshoots that @NellyG shared I also recommend following these charging tips. If you're still getting trouble feel free to post here so I can give you the next steps.
Keep me posted, I'll be around!
