01-16-2019 10:40
01-16-2019 10:40
Hi! My Fitbit Ionic is dead. I try everything that I could find on forums, even removing from my phone. The screen is off, I charged on the wall, on the computer, nothing works. I also cleaned the sensors. Please help and advise.
Best Answer01-16-2019 10:54 - edited 01-16-2019 11:04
@Daniela1210 have you tried cleaning the charging port on the back of your Ionic? If not it''s worth giving it go.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Best Answer01-16-2019 11:32
01-16-2019 11:32
I already did that before writing the post, but thanks for the reply.
Best Answer01-16-2019 11:34
01-16-2019 11:34
Best Answer01-16-2019 11:58
01-16-2019 11:58
In that case I would recommend contacting Customer Support to raise a case so they can assist you further.
Tony | UK
