12-22-2020 01:28
12-22-2020 01:28
After the recent firmware update, my ionic had started having one issue after the other, firsty the heart rate sensor was inconsistent and then had this clock Face issue , after changing the clock face was working properly and then again touch sensitivity was an issue. Now after loss of charge it won't charge again and stuck at 0%, I have tried other charge points still the same.
Best Answer12-23-2020 11:05
12-23-2020 11:05
Hi @Nivasmarine, it's nice to see you again in our Community Forums.
Thank you for sharing the issues you’re experiencing with your watch after the recent firmware update. I appreciate your troubleshooting efforts. I've shared your post with our Support team and they've mentioned that you already have a case with them. I know they will be glad to help you out and provide a solution, please keep an eye on your inbox. Meanwhile, you can confirm the complete troubleshooting instructions in this help article: Why isn't my Fitbit device's battery charging?
I'll be around if you have any questions.
