01-22-2019 19:40
01-22-2019 19:40
Hi all,
I recently traveled and my Ionic went out of sync. I tried to sync it and got stuck at "Unlock with Phone" screen and my phone refused to detect my ionic. So I had no choice but to remove it and try to add it as a fresh device.
The problem is now my phone detects the Ionic during set up and prompts me to enter a 4 digit code , but the screen of my ionic just says "Unlock with phone".
Is there anything I can do to get my Ionic to unlock and pair with my phone again ?
Best Answer01-23-2019 12:15
01-23-2019 12:15
@thewickedaxe Welcome to the Fitbit forums! Thanks for taking the time to share the experience you are having with Ionic during set up. Thanks for sharing all of those details regarding this and for removing Ionic from your account in order to sort this out.
Please try the following steps:
If this doesn't work please try the following:
If that doesn't work, you will have to perform a factory reset. Please note that the following steps will remove all the apps you previously installed on your watch; you will have to install them again after doing this:
This should certainly help you out with this.
Hope this helps. Let me know how it goes! ![]()
Best Answer01-26-2019 02:54
01-26-2019 02:54
Hey!
Thanks for your reply! Nothing worked so I had to factory rest my fitbit, 😞
Best Answer01-31-2019 16:16
01-31-2019 16:16
@thewickedaxe Thanks for your reply and for sharing the workaround you did.
Doing the factory reset solved this for you?
Keep me posted! ![]()
