08-23-2018 20:22
08-23-2018 20:22
Hi, I am deciding between buying Fitbit Ionic and Samsung Gear Fit 2. I am trying to understand general differences between the two except obviously being by different company 😉
One thing which is not clear to me is what am getting with Fitbit Ionic for extra price? Both of them are smart and support apps (ofc there is the difference between the quality of apps between samsung and fitbit generally) and Ionic has NFC payments.
Does anyone of you were deciding between the two and went with Fibit Ionic , if so why?
Best Answer08-24-2018 15:40
08-24-2018 15:40
Hey Marko,
I briefly owned a Samsung Gear Fit 2 prior to buying my Ionic.
1.) I have found GPS on the Ionic is far better and more consistent than the Gear Fit 2. Both tracked my cycle rides no problem but the Gear Fit 2 generated spikes in route mapping and inaccurately recorded distances when tracking my walks.
2.) The Gear Fit 2 did not record heart rate data during cycling activities due to an issue that Samsung had not resolved for more than six months. Whenever I cycled my heart rate readings flatlined giving me no data on the intensity of my exercise, although the heart rate feature worked fine with walks.
3) The Samsung Gear Fit 2 did not provide a step count for GPS tracked walks just mileage for distance and other metrics.
4) The Samsung App is okay to use and syncing is brilliant with a Samsung phone, but if you want to record a daily food log and compared calories burned and calories eaten you have to use a third-party App like MapMyFitness (which has a monthly subscription for Premium features), whereas a food log and calorie analysis is integrated in the Fitbit App.
Finally, the Samsung Gear Fit 2 needed charging every day with moderate use of GPS and other smartwatch features, whereas my Ionic lasts 2 days with the same level of activity and features.
I hope this helps.
Marc
08-24-2018 08:52 - edited 08-24-2018 09:08
Welcome on board @Marko3! Thanks for your question. We recommend checking out our comparison page at https://www.fitbit.com/compare, where you can see at a glance the features that each tracker provides.
Here is what Fitbit Ionic offers:
Additionally, here are some sources to find more detailed information about Fitbit Ionic:
Please let me know if you have a question our comparison page doesn't answer and I'll be happy to get you the information you need.
08-24-2018 15:40
08-24-2018 15:40
Hey Marko,
I hope this helps.
Marc
08-25-2018 08:04
08-25-2018 08:04
Thanks @Marc_PL, this response has been useful., although I did not have problems with point 1 and 2.
