08-08-2018
08:59
05:42
08-08-2018
08:59
05:42
Hi there I 've not had my Fitbit ionic watch for long and it is not charging it does go past the logo screen and it tries to charge I leave it charging and the screen goes blank
any suggestions are welcome
Best Answer08-09-2018 05:44
08-09-2018 05:44
Welcome to the Fitbit Community @AllanShearer! While reading your post I was wondering if by any chance you stopped using your Ionic for a while? If so, what I guess here is that probably your tracker ran out of battery. Have you tried charging it at least 1 hour? Even if you don't get anything on the screen I'd recommend charging your tracker at least 1 hour to see if the battery icon comes up after that period of time.
Charging fully takes up to 2 hours. While the watch charges, you can tap the screen or press any button to check the battery level.
If after the 1-2 hours you don't get anything on the display, check if the contacts on your tracker or charging cable are not dirty. Dust and debris can accumulate over time and prevent a charge. Try cleaning them by following these instructions.
How do you charge your buddy? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub.
If so, plug the charging cable into the USB port on your computer or a UL-certified USB wall charger.
Hold the other end of the charging cable near the port on the back of the watch until attaches magnetically.
I'd also try restarting your Ionic once more by following these steps.
Give this a shot and let me know the outcome!
Best Answer08-09-2018 14:34 - edited 08-09-2018 14:36
@MarreFitbit No, I only just got it from a friend of mine who stopped using it, It does turn on when the charger is in and when I leave it charging for 2 hours it has a blank screen even with the charger in I have ordered some rubbing alcohol I would like to know why that would work
19:22
09:52
08-09-2018
19:22
09:52
My Ionic wouldn't charge clicked on the help and then went to chat Talked to some one called Larry who didn't make me feel useless.
He fixed it in a flash I didn't lose any info.
Very happy with the service and my watch.
Moderator edit: format
Best Answer08-10-2018 09:54 - edited 08-10-2018 09:55
Thanks for the information provided. Please keep me posted with the outcome @AllanShearer. ![]()
Awesome @Bitz! I'm so glad to hear that you're back on track after reaching out our Customer Support Team. Thanks for the good comments, I'm happy to hear you're satisfied with the service and your watch.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please let me know!
Best Answer08-10-2018 10:05
08-10-2018 10:05
@MarreFitbit would like to know why rubbing alcohol would work to get it charging again
Best Answer08-10-2018 11:09 - edited 08-10-2018 11:11
As I've mentioned above @AllanShearer, sometimes the tracker or even the charging cable gets dirty. Making the dust and debris to be accumulated and prevent your tracker from being properly charged.
You can also try using a soap-free cleanser like Cetaphil, Gentle Skin Cleanser, or Aquanil. Make sure to rinse thoroughly, and dry well. ![]()
I'll be around if you need further assistance!
Best Answer08-16-2018 03:34
08-16-2018 03:34
@MarreFitbit Sorry for not getting back to you sooner I am getting a replacement Fitbit Ionic from Fitbit nothing was working I did every you asked me to thank you for trying to help me get it working
Best Answer08-16-2018 05:15 - edited 02-11-2024 09:35
Great news @AllanShearer! I'm happy to hear that you're receiving a new Fitbit. Thanks to you for taking the time to troubleshooting this with me. ![]()
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
