04-26-2018
11:21
11:22
04-26-2018
11:21
11:22
The gps was not connecting on my ionic when doing a run so I first tried shutting it down, that didn't work, so I did a factory reset of it. Now the ionic is on the setup screen, (where is shows the different languages) and when I try to connect it with my phone to setup over bluetooth my phone lists the ionic as an available device but then never pairs, just says, "Couldn't pair with ionic. Check your ionic settings and try again"... but I obviously can't check the ionic settings because it's stuck on the setup screen. Any ideas?
Best Answer04-26-2018 12:43
04-26-2018 12:43
I would say do another factory reset and put it on the charger. Make sure it has a good charge on it before you try hooking it up. Sometimes factory resets cause devices to think that there isn't any charge on the device, hence why they freeze and shut down. Charge it up all the way before you set it up.
one cruise ship at a time!04-26-2018 12:57
04-26-2018 12:57
I ended up uninstalling and reinstalling the mobile app and now it's working. Thanks for the reply
Best Answer04-26-2018 15:23
04-26-2018 15:23
@bhomer1 wrote:I ended up uninstalling and reinstalling the mobile app and now it's working. Thanks for the reply
You're welcome, glad it's working again. If the second factory reset didn't work, I would have recommended the uninstall and reinstall of the app anyways before contacting Support.
one cruise ship at a time!05-01-2018 11:26 - edited 06-25-2024 06:26
Welcome to the Fitbit Community @bhomer1, hope you're doing great! I'm glad to hear that you're back on track, thanks for sharing your good news. ![]()
Well, this usually happens when you performed a factory reset without before unpairing the device. Usually you should unpair your Ionic, forget Bluetooth (both Ionic and Ionic (Classic)) and perform the factory reset. To solve this issue should follow these steps:
This of course will be for future reference or in case another user jumps in here maybe experiencing the same inconvenience, so these steps could help.
Thanks for your help @DramaQueenDiva!
Let us know if there's anything else we can do for you.
05-02-2018 08:03
05-02-2018 08:03
Mine is doing the same thing now, but even after the uninstall of FitBit app and re-install, it still wont work and it still doesn't connect to the bluetooth.
01-04-2020 20:13
01-04-2020 20:13
Thanks I had real issues for the last few hours syncing. This sorted it out.
Best Answer01-09-2020 14:51
01-09-2020 14:51
I am having this problem now. I've had my Ionic for 2 years, all fine. It stopped synching 5 days ago and now I cannot get my phone to see it as an available device over bluetooth. I have force quit the app and reinstalled, shut Ionic and phone off etc but still no luck.
Can anyone advise? Thank you.
01-10-2020 05:48
01-10-2020 05:48
I have experienced the same problem over the last few days. Tried uninstalling, reinstalling, switching on and off, logging in and out.
I was concerned the Bluetooth component of the watch had broken but reading that you’ve had the same problem recently makes me think it may be a software issue.
Any advice is welcome!
Best Answer03-08-2020 15:25
03-08-2020 15:25
I have the same problem, tried all these steps and still no joy.
Best Answer04-19-2020 20:42
04-19-2020 20:42
Fitbit won't pair with phone or computer. Fitbit also keeps restarting. Time is wrong. Got it for Christmas 2019. I'm going crazy tried uninstalled app... turned phone off/restarted... turned bluetooth off and restarted. Any help would be appreciated. phone is a google pixel
Best Answer04-19-2020 21:02
04-19-2020 21:02
04-28-2020 00:20
04-28-2020 00:20
I had this issue. Eventually sorted it by unistalling app from.phone and doing full factory reset on device. I had been switching.watch on and off...no.good, it needed the full reset..
Mine is working ok now.
Best Answer07-22-2020 13:27
07-22-2020 13:27
I have been doing the same! Have uninstalled, reinstalled, factory reset and nothing is working! I got mine for Christmas 2019 also and am bummed that this is happening now! Is yours up and running or what steps have you taken to resolve this?
Best Answer07-22-2020 13:28
07-22-2020 13:28
I also received mine for Xmas 2019, will they replace it with no receipt? That's what I'm afraid of!
Best Answer07-22-2020 16:46
07-22-2020 16:46
Best Answer07-22-2020 17:03
07-22-2020 17:03
Yes that helps me a lot! I will be giving them a call!! Thank you so much for helping!!
