09-01-2018
20:46
04:53
09-01-2018
20:46
04:53
Reset my watch because time is way off. Also not syncing & wont connect to WiFi. Help! Gone through many steps trying to resolve to no avail.
Best Answer09-02-2018 01:51
09-02-2018 01:51
The time wont correct unless you can sync - that is the only way to correct it. So if you can get your Ionic syncing the time issue will resolve. What phone are you using? Have a look at THIS Help Article on Syncing Issues.
Helen | Western Australia
09-02-2018 04:56
09-02-2018 04:56
Welcome on board @Angie49! Thanks for taking the time to troubleshoot this on your own. Nice way to go!
@NellyG is right. Your Ionic won't show the correct time until your sync it. Please check the link she provides and make sure that the mobile device you're syncing with is included in our list of supported devices.
Also, I'd recommend taking a look at the article: Why won't my Fitbit watch connect to Wi-Fi?
Give this a go and let us know how it goes!
11-19-2018 20:30
11-19-2018 20:30
Tried resetting my Ionic because I got a new Iphone XR and now Im lost.
Troubleshooting everywhere just says to go to wi-Fi settings in the app on my phone, and since I deleted the old app and downloaded the latest, there no longer seems to be any W-Fi section to click on. It disappeared.
It worked fine before, but doesnt seem to want to connect now to the XR and especially with the latest fitbit app.
Best Answer11-19-2018 20:35
11-19-2018 20:35
Maybe I should just reset my Ionic? How do you restore to factory default so I can start anew. Im thinking thats the only way to get it to work. Its worked great for a year now on my Iphone 7, but I deleted the app from my old phone, then I "revoked" the old phone from the app. Still my XR phone wont find it.
Best Answer11-20-2018 14:27
11-20-2018 14:27
@tommyg29 Welcome to the Fitbit Community.
I'm sorry to hear about the difficulties you experienced when trying to sync with your iPhone XR. In order to perform a factory reset, on your Ionic, open the Settings app > About > Factory Reset or Clear User Data. Keep in mind that the apps and all personal data will be deleted from the device, including credit or debit cards you added. Instructions to set up your Ionic can be found on this article.
Hope this helps. Let me know how it goes.
Best Answer11-20-2018 16:04 - edited 11-20-2018 16:17
So for the past three days my Ionic will not sync. I have tried all of the troubleshooting and steps I have found on the forum and help section of fitbit. Can someone please help I have only had this like 3 months and it was my first fitbit and now I am really regretting this. I can't even get the device re set up after removing it. I am very frustrated and really need help.
After way more research I finally got this synced only through my PC. Still not happy that no app on any phone or tablet could make this work.
Best Answer11-20-2018 17:38
11-20-2018 17:38
@NatalieAD It's great to see you in the Fitbit Community.
Thank you for trying our troubleshooting steps before getting in touch. In order to address the issue better, please be so kind to let me know which phone do you have.
I'll be waiting for your response.
