01-14-2019 06:25
01-14-2019 06:25
Hi All,
I've had my ionic for close to a year & all on a sudden it won't turn on after charging. I've try to reset it and nothing is happening..please help I'm lost without wear my fitbit every day & can't afford to purchase a new one when my ionic isn't even 1 year old
01-14-2019 08:07
01-14-2019 08:07
Same thing just happened to me last week. Went to charge my Ionic and after 2 hours to check status, it wouldn’t turn on. Tried a hard reset by holding all three buttons for over 30 seconds...still nothing. Really don’t want to have to purchase a new one since this one has been a champ this whole time. What’s FItBit stance on this issue?
01-14-2019 14:42
01-14-2019 14:42
yep I love my fitbit! I have emailed customer support but haven't had a respose yet but will keep you in the loop when I get an answer @Levanen24
01-16-2019 07:23 - edited 01-16-2019 07:24
Hi @RhiJGray1522 and @Levanen24 nice to see you here, welcome to the Forums! ![]()
I'll do my best to help you out with this. Thanks for trying those steps.
Try to clean the contacts of your tracker. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this may damage the plating and result in corrosion.
Please restart your Ionic again. How are you changing your Surge? We recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker.
As a last resource, I would recommend following the steps below:
Make sure to check your phone Permissions and leave Location on to keep syncing and getting notifications with your phone, for more info check this suggestions from @ErickFitbit. ![]()
Hope this helps.
18:30
10:13
SilviaFitbit
01-17-2019
18:30
10:13
SilviaFitbit
Well... it just doesn't turn on at all so most of what you were
recommending I can't do yet. I've cleaned both the contacts on the watch
and the OEM charging cable with isopropyl alcohol and have plugged it into
a computer as suggested. I've tried both the 2 and 3 button methods and
still no luck. Left it on charging with OEM cable for 24 hours on a slow
charging source - still no luck. This thing is dead. What other options can
Fitbit give me to fix it?
Moderator edit: Removed personal information
01-17-2019 18:57
01-17-2019 18:57
@Levanen24 contact customer support. I did and they went through all these troubleshooters with me and still nothing worked so I was offered a replacement.
Best Answer01-17-2019 19:32
01-17-2019 19:32
@RhiJGray1522 wrote:@Levanen24 contact customer support. I did and they went through all these troubleshooters with me and still nothing worked so I was offered a replacement.
Yes this is exactly what happens most times. Go thru all troubleshooting protocols direct with Tech Support and if defective they will offer a replacement often on the spot. Everyone should follow this.
Best Answer01-17-2019 20:11
01-17-2019 20:11
The same thing just happened to me today. I’m so upset. I also use mine every single day and it won’t turn back on. It is completely dead. It had a 50% charge last night at 3am which is the last time it synced with my phone. I also only had mine just over a year. This really sucks especially considering how much money these cost.
01-17-2019 20:16
01-17-2019 20:16
I also can’t try any of the fixes suggested here because mine is completely dead and so I can’t reset it of course since it is dead. Nothing happens. How do I contact customer support and will they replace it or am I stuck footing the bill for a new one? Not that I have the money for one. A product this expensive should certainly last for more than a year.
01-17-2019 20:58
01-17-2019 20:58
@LisaYogini I just emailed them from the fitbit website
Best Answer01-17-2019 21:09
01-17-2019 21:09
Thank you. I will try that. I hope they will replace it as I surely can’t afford a new one
Best Answer01-18-2019 01:03
01-18-2019 01:03
Fingers crossed as I wasn't going to be able to afford I new one else so I'm very grateful
Best Answer01-18-2019 06:11
01-18-2019 06:11
01-18-2019 10:38
01-18-2019 10:38
You absolutely need to call them asap if you haven't already, because once 12 months is up there is nothing they will do but ask you to buy another watch.
I had two fail quickly, and the last one a few months outside my warranty date. Most of what is happening is from water slowly getting into the watch, I know this to be true because I've seen it happen to both of my watches.
If you can get another watch, consider yourself lucky and take advantage of it for sure. Maybe if you're even luckier it will last for a year so you might even get two years out of your $300 purchase. The truth is, these watches won't last, they were rushed out to compete with apple without proper testing... Be blessed and hopefully there is a good resolution.
01-24-2019 10:12
01-24-2019 10:12
Hey there @Levanen24. Thanks for the troubleshooting that you've tried and mentioned. In this case, I've created a case on your behalf with our Support team, they will continue assisting you.
Thanks for sharing your experience and tips @RhiJGray1522, @Whistler888 and @johneric8.
Hey @LisaYogini. Sorry to hear about the issue that you're experiencing.
Best Answer01-24-2019 10:24
01-24-2019 10:24
Exact same thing happened to me this morning. Talked to fitbit and because mine is out of warranty they are giving me a discount on a new purchase. $350 watch that only lasts 16 months is very disappointing. And no guarantees that this will not happen again! From reviewing the forums, that are a lot of people having the same problem. Seems more like a defect.
Most of our family is using a fitbit so I am kinda committed but really disappointed. Most expensive smart fitness watch ever....
Best Answer01-24-2019 10:25
01-24-2019 10:25
Thank you for the support. I was just given the option to receive a replacement tracker (without the band and charger) or receive 50% off a new watch. Obviously I chose the replacement. I am leary of investing more money into something that may be inherently defective. I truly want this watch to be wonderful as I have so enjoyed having it, but to have it die after only a year is not too reassuring particularly in view of the cost of this watch. It is certainly not cheap. Let’s hope I have a good one this time!
thank you again for the support
01-24-2019 12:23
01-24-2019 12:23
Wait, was your watch still under a warranty? and if not how long was it expired?
Best Answer01-24-2019 15:19
01-24-2019 15:19
I’m not sure but it must have been under warranty. I received it as a birthday gift last year - I don’t have a receipt. I sent a photo of the side of the box which I still had. It had a serial number on it and they said they were researching the warranty status and the next time I heard from them I was offered the choice of a replacement or half off a new one. I have to save the old band to put on it. I hope this one works better than the last. I do love the Fitbit when it works but I did have a lot of trouble with the black screen problems the whole time I had it. Always the sensor was flashing so I knew it wasn’t dead. This time no lights, no nothing so I Knew it was as dead as a door nail. Also about a week before it died I stopped receiving text notifications on it and all the settings were correct. I think it was dying then, and it died with a 50 or 60% charge, while I was asleep.
Best Answer01-26-2019 10:33
01-26-2019 10:33
Great to see you around @gdakin. Thanks for being a loyal customer. Each case is reviewed individually and the solution that's being provided by our Support team is based on the Fitbit Warranty.
I'm glad to hear that you received a replacement from our Support team @LisaYogini. Hope you can continue enjoying your Ionic and reaching your goals.
I'll be around if you need further assistance. ![]()
