12-23-2018
15:30
14:42
EdsonFitbit
12-23-2018
15:30
14:42
EdsonFitbit
Hi there, I have a ionic - about 2 months old and sometime payment works other times it doesn’t. There doesn’t seem to be any continuity. Anyone else have this issue?
I have tried paying on old and new terminals and it just seem temperamental!
Best Answer01-02-2019 18:34
01-02-2019 18:34
Best Answer01-02-2019 19:25
01-02-2019 19:25
@LowVibe75I have found the pin input to be more of a security setting.. In this link about Fitbit Pay explains it in detail.
When you take your watch off, and the moment you put the watch back on your wrist it prompts for a Pin, and there is the 24 hour cycle after the last Fitbit Pay when you have to put the pin in again. Sometimes I feel there is a random issue, and I put that down to security and welcome that. Maybe it's the point where the watch has temporarily lost the HR measurement and interprets that as a "watch removal", so you go to use Fitbit Pay and it needs the pin..
All of this for security, I welcome....
@LowVibe75 wrote:
Thank, yeah it’s a bit annoying.
I have found it works 100% of the time right after putting my PIN in. Today
I took the watch off my wrist and then launched FitBit Pay after it failed
the first time.
Once I put my PIN in it worked perfectly. This was faster than rebooting
the phone at least. If only there was a setting to ask for a PIN every
time, I would definitely use that because this seems to be the issue.
I tried to use it again not long after and it didn’t work, repeating the
above to get the PIN prompt worked again perfectly.
Cheers,
G.
Best Answer01-02-2019 19:41
01-02-2019 19:41
Best Answer01-02-2019 20:21
01-02-2019 20:21
@LowVibe75Thanks for the reply. Are you saying that you have to enter the pin every time you use FitBit Pay ?
Because I wear my Ionic 24/7 and as I mentioned in my post, there the random issue and other times as stated by Fitbit in the link. Over a waking day I rarely have to input the Pin.
If you're forced to Pin every time there is something amiss..
Here is the link to Support and depending on what country you're in you will get the option to email. I prefer to use that, put up with the first line of support... the waffle .. and then yopu reply with the facts again...
@LowVibe75 wrote:
I agree, this work works perfectly. I just wish there was a setting to ask
for it every time. For me, this is the only way I can get FitBit Pay to
work.
Best Answer01-02-2019 20:28
01-02-2019 20:28
Best Answer01-02-2019 20:53
01-02-2019 20:53
@LowVibe75I'm wondering if the Ionic is faltering on the HR detection.. Do you see many of the "--" because in my understanding that could be seen as a watch removal.
@EdsonFitbitThanks for the earlier input, could you throw some light on this issue because it's new to me.. I noticed today that the Unlock message with the padlock came up when I attempted Fitbit Pay.... How often will that occur or is it a timing thing ?
I can see three types of pin requests now, at the end of this para......and keeping in mind, during a day I rarely see these while using Fitbit Pay. My last calendar month there were 135 Fitbit Pay transactions, only two failures, because the Tap terminal could not contact the bank, re-tapping fixed that..
A dialup timing issue near Christmas..
Thanks.. Colin
Best Answer01-02-2019 21:05
01-02-2019 21:05
Best Answer01-02-2019 21:25
01-02-2019 21:25
@LowVibe75So to paint the picture, when you go to pay and press the LH button on the Ionic it shows the Credit Card image most of the time and will allow you to tap and pay or is this part failing ?
@LowVibe75 wrote:
I am deliberately triggering the PIN request otherwise FitBit Pay doesn’t
work. That’s why I take it off my wrist or reboot it. I don’t have an issue
with the PIN randomly requesting and FitBit working the rest of the time.
Sorry if I didn’t explain myself properly.
Cheers,
G.
Best Answer01-02-2019 21:45
01-02-2019 21:45
Best Answer01-02-2019 23:43
01-02-2019 23:43
@LowVibe75Thanks again... There is enough here for the moderators to give you some advice....
You will be asked the obvious questions.. Like OS level of the Ionic etc.....
Let's hope there is a positive solution for you because what you're experiencing shouldn't be happening..
@LowVibe75 wrote:
Hi, trying to paint the picture:
Hold down side button
Fitbit vibrates
Card comes up on screen ‘hold near reader’
Hold near reader, FitBit vibrates, nothing else happens
Sad face
Cancel transaction
Reset Fitbit (or remove from wrist briefly)
Hold down button
FitBit vibrates ‘tap to unlock’
Enter PIN
Hold near reader, FitBit vibrates, transaction completes
Happy face
If I use FitBit Pay again within say 10-15 minutes it works normally. After
that back to square one.
Hope this helps illustrating the problem.
G.
Best Answer01-03-2019 00:05
01-03-2019 00:05
Best Answer01-03-2019 00:38 - edited 01-03-2019 00:39
@LowVibe75 The only success I have had with Fitbit is to use the email option.. It gets well documented and you have evidence based data and you get results. Maybe because I'm in Australia and we have the email option. I believe that option is not available in some countries..
Fitbit have replaced two of my Ionics, both within 3 working days from OS to Australia. The first was a non working GPS and the second with dramatic battery discharge at about 4 days..
I'm happy with my current Ionic, and getting about 6.5 days battery, I still have the One and my others.. All working, but in "retirement" except the One...
Best Answer01-03-2019 01:22
01-03-2019 01:22
Best Answer01-03-2019 01:39
01-03-2019 01:39
Yeah - I’m in Oz too. So maybe it really is down to the slow tech here
Best Answer01-03-2019 01:58
01-03-2019 01:58
@LowVibe75@GreggaSeeing we are domicile in the same country let's now narrow the options..
I'm with the ANZ Bank using Visa card.. I have no issues with the three Fitbits since the release on day one, even with the other issues, but Fitbit Pay kept working.
Another plus with Fitbit Pay, I had my card compromised by a large electronics/appliance retailer a few weeks ago and Fitbit Pay was up and running within hours with my replacement Visa Card number, before my new Visa Card arrived in the mail. The attempted online theft never got the goods because the retailer's systems picked up the problem and froze my card in their system. A $4,500 TV set via their online system.. They blamed a "rogue" merchant/person somewhere in their system..
Best Answer01-03-2019 02:15
01-03-2019 02:15
Best Answer01-03-2019 02:48 - edited 01-03-2019 04:16
@Colinm39 Hi Colin, I’m in Aus too and having Fitbit Pay issues too with my Ionic, which is why I’m reading this thread - but what caught my eye is that you say you get 6.5 days out of your Ionic’s battery. Do you use the GPS function much? I am lucky if my Ionic lasts more than 2 days between charges, if I use the GPS.
Thanks
Best Answer01-03-2019 03:22
01-03-2019 03:22
@Robyn-TWRNo GPS, I have done all of that on all of my Fitbits including the Ionic and decided the effort while the heavy consuming the Ionic battery wasn't worth the effort... The benchmark is only 10 hours of continuous GPS use and nearly flat.. I have GPS tracked all of my walking routes and verified them on the Android. So I'm just interested in my times and speed.
I use Workout most of the time, for brisk walks, sleep analysis, gardening, shopping at the malls because I brisk walk between shopping points.. I have all notifications working as well.
I will be losing my Premium in March
and rather than fiddle with the new export for HR data I now use PulseWatch's free HR analysis which picks up your data from your Fitbit site. If you use Workout you get about 30 HR plots/minute, if not you only get 8 HR plots/minute
A little off subject, but hopefully imparting knowledge is always a feel good situation in these forums.
Here is the PulseWatch link and it's fast and exportable into Excel...
Best Answer01-03-2019 03:26
01-03-2019 03:26
01-03-2019 03:41 - edited 01-03-2019 04:17
