12-25-2017
11:14
08:10
12-25-2017
11:14
08:10
Every time I enter my pin, so I can update my credit card info, it shuts down and says it can't connect to fitbit and fails. It doesn't matter what platform I try to use, Android, iOS or Windows 10. Anyone else having this problem? Or know a fix?
12-29-2017 08:13
12-29-2017 08:13
Welcome to the Fitbit Community @Jimdmd! Hmmm... strange my friend, I haven't had this issue so far.
I'd recommend the following:
Give this a shot and let me know how it goes!
06-12-2018 06:18
06-12-2018 06:18
I've tried all those steps. still not working.
I'm trying to update the credit card details in the wallet. everytime I get asked to input my pin, it says "error unable to connect to ionic".
what do I do? the stores credit card is no longer in use and I need to put my new one on there
06-12-2018 06:46 - edited 06-12-2018 06:48
Hey there @messnakey, thanks for stopping by and for trying the suggestions shared here. Nice way to go!
To a remove or delete a card:
If you enter an incorrect PIN code 10 times, you're prompted to unlock your Fitbit watch with your paired phone. For instructions, see How do I use the device lock on my Fitbit watch?
As an aside note, after resetting your PIN code, you must add your cards to Fitbit Pay as if you were setting it up for the first time.
Hope this helps. Keep me in the loop!
06-12-2018 15:30
06-12-2018 15:30
06-14-2018 06:52 - edited 02-11-2024 11:22
Thanks for the details @messnakey! Let's try the following:
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below:
After making sure about that, try setting up your Ionic again.
