09-04-2019 08:37
09-04-2019 08:37
My Fitbit Ionic got device locked so i tried to reset my PIN-code. After a while of not getting connected i lost patience so i tried to delete my Ionic from my phone and then reconnect it, as this is what i usually do when it won't connect. When i try to set up the device now it is supposed to show a 4 digit code on my Ionic to write on my phone, but on the Ionic it only shows "Unlock with Your Phone" so i can't connect it to reset the PIN-code. What should i do?
10:45
08:07
09-05-2019
10:45
08:07
A warm welcome to the Community @jonna1999. Thanks for the details mentioned and the troubleshooting tried.
To unlock your device with your phone:
If you're unable to do the procedure posted above, you might want to perform a factory reset.
Let me know how it goes.
Best Answer12-18-2019 05:02
12-18-2019 05:02
How do I do a factory reset when I can't unlock the phone or connect to it via bluetooth?
Best Answer12-19-2019 10:23
12-19-2019 10:23
@sllarsen Welcome to the Community. Thanks for the details mentioned.
I've shared your post with our Support team and they've mentioned you already have a case with them. Please continue the communication through email, they will continue assisting you.
I'll be around if you have any additional questions.
