12-01-2020 11:30
12-01-2020 11:30
Hi all
I have an issue with the ionic device, it can't connect to the phone. It's been 2 or 3 months then I use it again. I still remember my pin that I set up way back, and now when i turned the device on and scroll or access the settings/menu, it's asking to "unlock with your phone". I've install the the app on my new phone but then it's not syncing because I will have to access the bluetooth settings on the ionic device which is not letting me because its locked. I've tried headrest by hold the left + right bottom button, logo appeared, disappeared but still same issue.
Please can someone help me on how to resolve this issue.
Regards
Jack
12-01-2020 11:52
12-01-2020 11:52
@Jackedlan, try the instructions for unlocking the device to see if that clears it:
12-01-2020 21:41
12-01-2020 21:41
Thanks for the update and quick reply. I'll be sure to keep an eye on this thread.
12-02-2020 13:20
12-02-2020 13:20
If it says to unlock with the phone, Do not remove the tracker from the app or Fitbit account.
You don't need to connect the tracker to the phone or even use your phone.
If you are unable to follow @USAF-Larry instructions above with your phone. Beg and borrow a phone, but turn the Bluetooth off on your phone first.
Then
