02-14-2020 04:01
02-14-2020 04:01
As of yesterday my Fitbit ionic won't turn on or charge or factory reset I have tried charging on different outlets including my mac, nothing works. I have tried all the different kinds of factory resets nothing works. Any suggestions would be great.
Best Answer02-15-2020 02:05
02-15-2020 02:05
If so, plug the charging cable into the USB port on your computer or a UL-certified USB wall charger LiteBlue.
Best Answer02-18-2020 06:56
02-18-2020 06:56
Thanks for the response but I tried that as well and not a flicker.
Best Answer02-19-2020 02:26
02-19-2020 02:26
I had the same problem, overnight it didn't charge, while weeks on end it functioned perfectly. Nothing worked. Unfortunately I had to return the Fitbit Ionic, I now have a new one. It seems that we're not the only ones with that problem, when googling, the problem turns up more than it should.
