01-11-2018 15:34
01-11-2018 15:34
One of the reasons I bought my Ionic is to monitor my sleep. It seems to be very inconsistent in that there can be several hours during the night that don't get monitored. The dashboard will show two sleep entries for the night with a gap in the middle and it can happen at any point in the night. Has anyone else experienced this and does anyone know a solution? The band seems to be tight enough. Thanks in advance for any help.
Best Answer02-04-2018 06:01
02-04-2018 06:01
@Djscoe Welcome to the Fitbit Community! Sorry for the delayed response. Thanks for reporting this. Are you still experiencing the same?
I'd recommend performing a restart on your Ionic. This should help to better the sleep tracking and avoiding those gaps.
Also, for any night that was tracked incorrectly, you can edit the sleep log for it to show correctly. This should help you out to get them to show correctly.
Additionally, check this helpful article about sleep. It is always good to know!
Hope this helps. Keep me posted! ![]()
Best Answer02-04-2018 08:28
02-04-2018 08:28
Hi Djscoe, I get the same thing from time to time. Most nights are fine but sometimes I lose an hour or so in the middle of the night. I haven't done a reset as suggested as most nights are ok. If that works for you will you let us know and I will maybe give it a go although it's hard to understand why that will solve the problem? ta.
