03-23-2019
23:27
11:17
YojanaFitbit
03-23-2019
23:27
11:17
YojanaFitbit
My gps wont connect at all I've rebooted it, left it to try and connect for at least ten mins and even stayed outside to get a better signal but still wont work .its always worked perfectly fine before .
Moderator edit: Updated subject for clarity.
Best Answer03-24-2019 11:16
03-24-2019 11:16
Hi @Scottie2017 nice to see you here again. Thanks for reaching out the Forums!
I appreciate the details on your post, I'd my best to help you out with the issues that you're having with your Ionic. I'd suggest checking this article: Why isn't GPS working on my Fitbit device? Then you can restart your Ionic and give it a try once again.
Please keep me posted on the resolution.
Best Answer03-25-2019 02:33
03-25-2019 02:33
