04-12-2018 10:16
04-12-2018 10:16
I just bought a Lifecycle GX which has a Polar HR compatible receiver. My question, do I have to buy a Polar type chest monitor, or can I use my Fitbit Ionic? (so that I can use the full data from the spinning bike computer)
04-12-2018 11:50 - edited 04-12-2018 11:55
No, Fitbit Ionic does not talk to Polar gear or Garmin or Suunto. In fact at this moment Fitbit does not talk to any HR strap.... The only thing you can pair to the Fitbit Ionic right now are bluetooth headphones made by various brands but not all work correctly.
04-12-2018 10:29
04-12-2018 10:29
The Polar works with the chest strap. So you need to buy a Polar chest strap.
Ionic is a watch that uses Heart rate on the Monitor it self.
Wendy | CA | Moto G6 Android
04-12-2018 10:30
04-12-2018 10:30
Also not knowing this model you bought you should really ask this in the Polar forum. For all I know it doesn't need a chest strap. But you need to do the research over there
04-12-2018 10:58
04-12-2018 10:58
Thanks for the reply, however its really a question if Fitbit 'talks' to Polar compatible HR receivers. As the spinning bikes built in computer isnt branded Polar,....they arent going to know either.
04-12-2018 15:04
04-12-2018 15:04
According to the Versa manual this option is coming to the Versa, my guess since the two run the same IS that there is a chance the Ionic will be getting this option in the future.
04-12-2018 16:56
04-12-2018 16:56
@Rich_Laue wrote:According to the Versa manual this option is coming to the Versa, my guess since the two run the same IS that there is a chance the Ionic will be getting this option in the future.
@Rich_Laue I can't find anything in Versa manual to suggest that it will support a) sending HR to gym equipment, or b) pairing with external HRMs (chest straps).
I did find this thread:
Where Fitbit employee confirmed no support for external HR monitor.
Could you please point out the page number in the Versa manual, where it states that support for broadcasting HR to external equipment, or support for pairing with external HRM will be supported?
Thanks
04-20-2018 03:16
04-20-2018 03:16
Many thanks for all the replies. It does appear I have to buy a chest strap. However I would be intrigued to learn if Fitbit have considered this issue? Clearly I will still wear my Ionic to track my exercise, however the data the spinning bike has is more useful as it will have my miles, RPM etc. Its also directly in front on a large LCD screen. If the Ionic was able to talk to the receiver then I wouldn't need to put money in Polars pocket....perhaps thats the issue!
