01-11-2018 17:27
01-11-2018 17:27
My bluetooth headphones are paired to my ionic but when I turn them on they won't automatically connect. I have to go into settings and click "connect to headphones" and then select them. These same headphones will auto connect to my iphone as soon as I turn them on. Is there a way for them to auto connect to the ionic? thanks
02-10-2018 11:16
02-10-2018 11:16
I just un-paired then re-paired the same headphones (which I had tried before) and that seemed to do the trick this time.
Best Answer02-09-2018 13:50
02-09-2018 13:50
Mine used to connect automatically and now they don't. I'm not sure if it was due to an Ionic update or not. It's very annoying have to go through a timed connection process every time I want to listen to Pandora from my Ionic (swiped down-> touch ..." -> touch device -> touch Sony bluetooth headphones, back, back).
Fitbit - please advise.
02-09-2018 14:04
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
02-09-2018 14:04
Make sure your Ionic screen is on just before you turn on your Bluetooth headset.
02-09-2018 20:49
02-09-2018 20:49
Long time user, first time I've responded. I've learned a lot reading these forums. Even though the problems are the same, the solutions could be one of many. I figure I'll throw my 2 cents in and see if it could be the solution to your problem. When I had more than one Bluetooth headset paired, I had to connect every time. When I deleted all but my favorite pair, it would connect as soon as I turned it on.
Best Answer02-09-2018 21:50
02-09-2018 21:50
Still didn’t work but thanks
Best Answer02-09-2018 21:53
02-09-2018 21:53
I only have one paired with the ionic. I tried turning off the Bluetooth on my phone since it connects with it immediately, thought maybe if that wasn’t available it would go to my ionic but that didn’t work either. Thanks anyway
Best Answer02-10-2018 00:03
02-10-2018 00:03
I'm having more fun trying to trouble shoot the Ionic than I would have if it was perfect! Maybe it's the brand of headphone. The 2 I removed had a poor quality sound. The one I kept actually says, "Headphones connected" seconds after I turn it on and the music starts to play.
Best Answer02-10-2018 01:11
02-10-2018 01:11
Wow I didnt realise the should connent automatically! I have flyers and the old ones never xonnected automatically. I now have a replacement pair (for another minor issue) and these connect as soon as I turn them on. I did t think it was odd withbthe first pair because I didnt realise it should just happen! I did find it a bit annoying though lol
Helen | Western Australia
02-10-2018 10:39
02-10-2018 10:39
Thanks Vern3535. I appreciate it. I tried that but no joy. What did work was having the ionic on the Pandora screen and then turning on the headphones. Of course it could have been a combination of both!
Best Answer02-10-2018 10:40
02-10-2018 10:40
Thanks MassiP! That worked!
Best Answer02-10-2018 11:08
02-10-2018 11:08
I don’t think it’s the headphones because I get the “Headphones connected.." message from my phone immediately
Best Answer02-10-2018 11:16
02-10-2018 11:16
