12-08-2017 13:39
12-08-2017 13:39
Is it possible for ionic to have heart rate display permanently, and the screen to remain on? I use fitbit for kayaking, and want to check HR at a glance without losing paddling momentum when i need to activate the screen.
Best Answer12-08-2017 13:52
12-08-2017 13:52
Hi, @BobbyBubblegoos, it is possible to set the Ionic display permanently on when it is in exercies mode. So you would want to track your kayaking as a "workout" using one of the exercise shortcuts and click the gear icon on the top left corner of the workout screen and select always on,
Later, if you choose, you can also rename your "workout" as "kayaking".
If you have any further questions, please post again. There is always someone here to help. Welcome to the forums!
Best Answer12-08-2017 13:57
12-08-2017 13:57
Thanks Julia!
