10-18-2017 01:54
10-18-2017 01:54
I recently was given an Ionic.
Is there some way that the heart rate numbers can be set to be seen on the screen all the time when running, like the distance meter when the GPS is on? Secondly, can the Ionic be set to set out a audible or physical alert when the heart rate crosses a preset number.
Many thanks for any replies.
10-18-2017 02:26
10-18-2017 02:26
Hi, @Baldrunningman, the answer to your first question is "yes" -- go to your run settings on the watch and choose "always on" . Also in the run settings you will find "customize stats" where you can choose which information is displayed on the screen.
You can swipe left on the watch to display different info and the watch will show the stat you choose until you swipe again to change.
The answer to your second question is "no". There is not an alert you can set for heartrate zones, etc. You might want to vote for this popular feature request. It refers specifically to Charge HR and Surge, but if implemented it would certainly apply to the Ionic. You also might want to vote for this request specific to the Ionic.
10-18-2017 01:52
10-18-2017 01:52
10-18-2017 02:26
10-18-2017 02:26
10-19-2017 03:22
10-19-2017 03:22
