08-15-2018
19:16
05:55
08-15-2018
19:16
05:55
Within the last week or so the HR on my device seems way off. Today I was sitting and had been for at least 5-10 minutes. I looked at my device and my heart rate read 105. This was odd to me. I wasn’t moving. I didn’t feel like my heart was beating quick. My resting heart rate is usually between 58-60 bpm. I performed a manual HR check which was around 62 bpm. I turned the device off and let it restart and I’m still having issues. Anyone else noticing this problem?
08-16-2018 05:57 - edited 02-11-2024 09:34
It's nice to see you around @Cheycarrier! Thanks for taking the time to troubleshooting this inconvenience with your heart rate readings, nice way to go!
As you may know, your heart rate may be affected by any a number of factors at any given moment. Movement, temperature, humidity, stress level, physical body position, caffeine intake, and medication use are just a few things that can affect your heart rate. Different medical conditions and medications can impact your heart rate as well.
Your resting heart rate is usually higher than your heart rate while you are asleep, so don’t be surprised if your resting heart rate is higher than the lowest number that you see in your heart rate graphs.
Your tracker can have difficulty finding a signal, typically due to the tracker's fit. For example, wearing your band tightly may constrict blood flow in your wrist and affect the signal. We recommend experimenting with how high you place the tracker on your wrist. When you're not exercising, wearing the tracker just above the wrist bone--as you would a watch--typically works fine. However, moving the tracker up a couple inches can be helpful during high-intensity exercises or exercises that cause you to bend your wrist frequently. Please double check our recommendations for wear and other tips shared by @SantiFitbit.
Note that on Fitbit Ionic, the heart-rate value appears gray if your watch is searching for a stronger reading.
08-17-2018 04:38
08-17-2018 04:38
@MarreFitbit Thank you very much for your reply. I feel as though I have my device placed properly and right/loose enough however I will make some adjustments and see if things change.
08-17-2018 04:52
08-17-2018 04:52
Sure thing @Cheycarrier! Let me know if you see an improvement in your heart rate readings.
