02-25-2019 00:40
02-25-2019 00:40
As a hiker I'm more interested in measuring my climbing in meters rather than floors. Can my Ionic be setup to do that? If not how many meters is a floor equivalent to?
02-25-2019 00:55
02-25-2019 00:55
It can't track meters at the moment. It tracks a floor when you gain 10 feet (3 meters) in height while continuously walking.
The tricky thing about using it for altitude gain when hiking is that only completed "floors" count. So, if you rise 9 feet, level off for a few steps, then rise another 9 feet then you rise 18 feet but get zero floors.
01-01-2023 20:56
01-01-2023 20:56
Can you explain that a bit more clearly, please?
Best Answer01-02-2023 08:29
01-02-2023 08:29
Hello @philevedoug and welcome to the Community. I hope I can help you. Fitbit’s floor counter uses a relative altimeter. It looks for a change in barometric pressure when walking up stairs or a hill. It’s very different from a hiking altimeter, which uses GPS coordinates.
Using Steve’s example, if you climb less than 10 ft (9 m), then level off, you don’t get credit for a floor. My real world example. A nearby trail has a 1400 ft elevation gain. I usually get about 125 floors, not the expected 140. The trail goes up, levels off, and goes down before going back up.
Fitbit seems to count floors as a fun fact. We are encouraged to take the stairs instead of the elevator to be active. It’s your way of saying, “See, I took the stairs.”
Laurie | Maryland
