01-31-2018 06:34 - edited 01-31-2018 06:36
How do I add rowing, cross country skiing, and snow shoveling to the "exercise shortcuts" on the Ionic / phone ap?
Thank you in advance.
Best Answer01-31-2018 08:30
01-31-2018 08:30
I'd be great to be able to add any exercise to the ionic, though only the following can be added:
Run
Walk
Bike
Swim
Treadmill
Weights
Workout
Interval Workout
Elliptical
Hike
Golf
Stairclimber
Tennis
Spinning
Yoga
Bootcamp
Circuit Training
Kickboxing
Martial Arts
Pilates
You can check which one is similar, and add it to your ionic from the device settings page at https://www.fitbit.com/settings/device (then clicking on the ionic), and edition the exercise shortcuts.
You can also manually log those activities.
Best Answer01-31-2018 19:14
01-31-2018 19:14
@BelgianJoeI use the Ionic preset Workout for those activities that GPS isn't an issue because it doesn't have the GPS option. I then rename the activity to match what I was doing. Of course if you don't want GPS you can use Workout for snow skiing.
The downside is you must create the names of the Custom Activities on your PC first..if you want to rename the Workout on your phone.. Or .... if you rename Workout on the PC it will prompt for a Custom Activity name if the name doesn't exist and that name will be available on the phone.
You only have one go at renaming...
wrote:How do I add rowing, cross country skiing, and snow shoveling to the "exercise shortcuts" on the Ionic / phone ap?
