02-25-2018
09:28
07:43
02-25-2018
09:28
07:43
how can i read my text messages? i get the alert that I got a message, but i can't seem to read it.
thanks
Best Answer04-17-2018 07:41
04-17-2018 07:41
Welcome to the Fitbit Community @ShapMom34!
I'm sure that what's missing here is what my friend @Working_on_mama has pointed out.
Let's try the following step-by-step:
In addition, do the following:
Thanks for helping out folks @NellyG @Cyclonetog! ![]()
Give this a go and let us know if you can read your messages after following these steps!
Best Answer02-25-2018 09:54
02-25-2018 09:54
When your clock face is showing, swipe up from the bottom of the screen with your finger.
You can clear them from there also.
Best Answer02-25-2018 10:39
02-25-2018 10:39
Best Answer02-25-2018 10:48
02-25-2018 10:48
Oh, sorry...
which phone do you have? I get the first part of the message and it expands if I tap it.
I'm using iPhone 6.
Best Answer02-25-2018 11:20
02-25-2018 11:20
Best Answer02-25-2018 11:25
02-25-2018 11:25
I just went on this page
and it shows that should be compatible. Sorry I can't be more help than that.
Best Answer04-16-2018 21:16
04-16-2018 21:16
I was having the same issues and realized it was because I had my text message preview turned off. I have a Samsung galaxy s7. On your phonse, open you text message and in upper right corner go to settings>notifications>preview text and make sure it' turned on that should fix it.
04-17-2018 00:24
04-17-2018 00:24
I was just going to say check all your phone settings, but @Working_on_mama has hit the nail on the head!
Helen | Western Australia
04-17-2018 07:41
Best Answer09-03-2018 16:12
09-03-2018 16:12
I had the same issues and realized it was because I had my text message preview turned off. On your phone, open your text message and in upper right corner go to settings>notifications>and make sure preview text is turned on that should fix it.
Best Answer09-04-2018 07:46 - edited 03-27-2024 13:15
Welcome here @MeTriMan! I'm glad to hear that you're getting your texts after tuning on the preview option.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted! ![]()
09-04-2018 08:55
09-04-2018 08:55
Best Answer09-16-2019 12:05
09-16-2019 12:05
I don't have Preview message icon on my Samsung Galaxy 6S EDGE Plus. I'm getting notification of the message on the watch, but cannot read it. I see on Ionic is 2 message options: 1. Open (if you select this option than message opened on my phone) or 2. Clear (if you selected this option, than nothing happen)
