03-13-2018 11:51
03-13-2018 11:51
I will be doing some scuba diving refresher courses in a pool. As long as I stay above 50m how long can I stay submerged for with my ionic?
Best Answer03-13-2018 12:03
03-13-2018 12:03
Specs don't specify a time limit. As long as you stay above the 50 meters depth spec, I believe you are safe with any length of time.
Best Answer03-13-2018 12:21
03-13-2018 12:21
It's also worth remembering that it's only rated to 50M at static pressure. Once you start moving around with it the pressure will increase. I really wouldn't recommend scuba diving with a watch rated for 50M.
