09-30-2017
05:57
09:17
09-30-2017
05:57
09:17
Hey Pals,
is there a way to re calibrate the Ionic?
I was in my car when it said to lay it on a flat surface, but i was not able to in the car...
03-20-2018 14:27
03-20-2018 14:27
With respect if the calibration is to do with resetting the GPS etc, why is it asking to be plugged into the charger and put on a flat surface? My ionic has only started doing this since the fiemwareup date yesterday (which has rejigged all the info the ionic gives, bilut in a much better user friendly way!) Although I am still pressing the wrong buttons while in the gym! Heyho, the new fuemwfir only went on yesterday ebeneve and the calibration message started after this! So back to my initial question why if it's to do with GPS why is it plugged in and on charge in a static position on a flat surface?
03-21-2018 09:15
03-21-2018 09:15
Upon receiving the notification that I needed to calibrate my Ionic, I plugged it in. But as soon as I set it down, the magnetic connector to the charging cable came just a bit off of the device, ending the calibration. Is there any way to manually initiate calibration on the Ionic?
03-21-2018 11:41
03-21-2018 11:41
I'm having the opposite experience. For example, last Monday while driving in my car from out of state to home for 6 hours my Ionic tracked over 26,000 steps. Last Thursday while home sick in bed my Ionic tracked over 8000 steps.
03-21-2018 11:43
03-21-2018 11:43
@SunsetRunner@patch832- have you connected the tracker to the power cable, plugged into a working USB port, and laid it down for 15 seconds to complete the calibration?
03-21-2018 11:46
03-21-2018 11:46
Had mine nearly 6 months now even put fitbit os 2 on the other day and never once in that time has my ionic asked me to calibrate it.
03-21-2018 11:46
03-21-2018 11:46
Every time! Doesn't seem to matter...
03-27-2018 18:01 - edited 03-28-2018 04:29
It’s obvious isn’t it? There’s a design flaw, possibly hardware level, and this is a stop-gap solution to what would otherwise be a hardware recall. Someone screwed something up big time and now us owners are the ones that suffer. Ever have to calibrate your Surge? Nope.
03-27-2018 18:32
03-27-2018 18:32
Yup!!!! I have...
03-29-2018 11:07
03-29-2018 11:07
I don't know about that. I went up and down the stairs (2 flights) 10 times in a row and it only increased my floors by 1. Then I walk around at work all day and never go up any stairs and it says I climbed 25 floors. I don't think any calibration can fix that, it's just not using the right data to estimate.
03-29-2018 12:54
03-29-2018 12:54
03-30-2018 15:18
03-30-2018 15:18
Lucky me got a Fitbit Iconic for my birthday,and coming from a Flex i am new to this whole calibration thing.. Whenever I plug it in, face down on a soft service, I start calibration and a big red X appears on the screen which I have understood meant it was working and I should just let it be. However the same message alwats results - failed to calibrate - with an option to try again or try later. I have tried countless times with the same result. Any ideas what I'm doing wrong @MarreFitbit? It sounds like you know what you're talking about! So your help would be greatly received, thank you. ☺
03-31-2018 00:05
03-31-2018 00:05
03-31-2018 20:12
03-31-2018 20:12
Thx for letting me know 😏 not so great hey. However, I continue to enjoy the heart rate tracking side of the Iconic especially - it seems to me all that info must make for quite an accurate recording system. I look forward to learn more as I anticipate getting even more out of it. 👏
04-01-2018 07:58
04-01-2018 07:58
I contacted Fitbit Support via CHAT on Friday. At first it appeared the support person was not aware of the Calibration issue. I explained multiple times that it started after the most recent Firmware update. I also explained that I did a factory reset multiple times and rebooted the device also multiple times but the issue still happens. They finally stated they had heard of a few of these incidents to which I explained there are numerous complaints about this issue on the forum. They finally admitted they are aware of the issue and are working on it. There is no ETA.
04-01-2018 13:55
04-01-2018 13:55
It seems there is a greater problem at hand. Thanks for detailing your story. Here is to hoping this is sorted soon!
04-02-2018 12:10
04-02-2018 12:10
Fitbit have responded to one of my support requests, confirming that there is a known issue with calibration with the Ionic. See text below. I guess the fix may be released as another software update at some point.
"Based on the calibration message that you keep receiving after the firmware updated, we would like to inform you that we are aware of the problem and are working to resolve it as quickly as possible."
04-02-2018 17:54
04-02-2018 17:54
Keep trying to calibrate my ionic and it keeps failing. Any suggestions?
04-03-2018 01:43
04-03-2018 01:43
04-04-2018
12:30
06:02
JuanJoFitbit
04-04-2018
12:30
06:02
JuanJoFitbit
My watch won’t calibrate ever since the update this past week. It keeps giving an error. Does anyone know what to do?
Mine won’t recalibrate either. It keeps saying check the sensors but they aren’t blocked:(
Moderator edit: merged reply
04-04-2018 12:33
04-04-2018 12:33
I’m having the same issue since the software update
