09-30-2017
05:57
09:17
09-30-2017
05:57
09:17
Hey Pals,
is there a way to re calibrate the Ionic?
I was in my car when it said to lay it on a flat surface, but i was not able to in the car...
04-04-2018 17:54
04-04-2018 17:54
Every time I tried to calibrate my Ionic, it tells me “make sure sensors are cleared” or something like that. I plug it in and lay it on it side (with and without wrist bands) and I get the same thing over and over again. What is wrong and how can I fix this? Any help with this would be greatly appreciated. Thanks.
Best Answer04-05-2018 05:59
04-05-2018 05:59
Best Answer04-05-2018 06:21
04-05-2018 06:21
Best Answer04-05-2018 07:11
04-05-2018 07:11
Best Answer04-05-2018 12:29
04-05-2018 12:29
I am struggling to get my fit fit to calibrate I am not sure it why it doesn’t work it’s plugged in on charge and laid on it side on a flat surface p,ease help
Best Answer04-06-2018 06:30 - edited 04-06-2018 06:31
@Pipbellsham it's a known issue since the OS 2.0 update. Many of us (myself included) are suffering the inability to complete calibration and receive daily reminders to calibrate. Fitbit indicates they are working on a fix in the next update.
04-06-2018 06:49
04-06-2018 06:49
I have had my ionic since last october and not once has it asked me to calibrate it not even with os2 on it .is this normal or is there some wrong with mine.i know the milage on the steps is way off compared to my surge over a mile difference.
04-06-2018 08:58
04-06-2018 08:58
Best Answer04-06-2018 09:09
04-06-2018 09:09
Hi i did contact fitbit support they said they cant make it happen just got to wait till it asks to be calibrated .would have thought in 6 months it would have asked once to be calibrated.
04-27-2018 20:24
04-27-2018 20:24
Has anyone had the issue of it not calibrating when plugged in? I get this message every day and plug it in after a few seconds a big X comes up and says retry. Any suggestions?
Best Answer04-28-2018 10:39
04-28-2018 10:39
Best Answer05-11-2018 21:37
05-11-2018 21:37
I updated and it asked to recalibrate. I accidentally clicked off of it and now i can't get it back. I feel like my step count is off (way under) anyway to bring this up manually
Best Answer05-15-2018 04:50
05-15-2018 04:50
My ionic was re charged and calibrated then after if I do a 100 steps it might register 1 or none, I’ve tried doing a exercise and nothing. Can I re start the ionic then calibrate again.
Best Answer05-15-2018 06:45
05-15-2018 06:45
Best Answer06-08-2018 14:32
06-08-2018 14:32
How to calibate for fitbit ionic
Best Answer06-10-2018 19:07
06-10-2018 19:07
When I plug it in, a large green "checkmark" shows on my screen. I didn't know if I should touch it or not, so I did. Later today I got another message that I needed to calibrate. So, I assume that when the checkmark shows up, I do nothing and let it do it's thing??
Best Answer06-11-2018 08:18
06-11-2018 08:18
@DSMTC the green checkmark is indication it has completed successfully. I say that with emphasis as my Ionic presents this daily at 8:00 PM. (until a recent restart of the Ionic)
Best Answer07-06-2018 06:19
07-06-2018 06:19
My Ionic hasn't been calibrated since OS2 came out several months ago. At that time it would never succeed, no matter what I did. It needed power for that attempt at calibrating.
After the most recent update, I am asked to update every evening at 8pm. No instructions asking for any special conditions at all, just calibrate or later.
Since this is ongoing, I now just tell it to update. The same response every time - whether I set it down, charge it, continue in the middle of a walk, whatever. No matter what, it instantly changes to a green check mark.
So, I now "calibrate" every day at 8 pm.
I hope it doesn't really need calibration!
07-06-2018 06:39
07-06-2018 06:39
@IronicIonic If you haven't done so, reset you Ionic. There are instructions here:
https://community.fitbit.com/t5/Ionic/Resetting-Your-Ionic/td-p/2232205
I have encountered the same, daily calibration reminder on my Ionic after the past two updates. After resetting my Ionic the reminders have stopped. (Granted, I don't know if the Ionic is calibrated or not. Comparing step count and heart rate with an older tracker show similar results, so I'd say my Ionic is calibrated)
Best Answer07-15-2018 01:37
07-15-2018 01:37
My Fitbit ionic asks me to re calibrate
itsays start now or later
i click start now when it is plugge in but every time after about 20 seconds it says it failed to calibrate
this has Ben going on for several weeks now
