07-03-2019 09:51 - edited 07-03-2019 09:53
I am trying to get my watch to stop turning on while I am trying to sleep.
I have already set the "Screen Wake" to manual but, even after syncing with my Android phone and powering the watch off and on again. The setting doesn't seem to be sticking.
The screen still seems to wake every time I double tap it.
Thanks in advance for your help!
07-03-2019 09:56
07-03-2019 09:56
The setting prevents from waking up on wrist motion. As far as I am aware you can't disable wake up on touch.
07-03-2019 09:56
07-03-2019 09:56
07-03-2019 10:12
07-03-2019 10:12
Thanks for the reply!
I am hopeful then that between the Manual setting and Dim screen setting, I should have far fewer seemly random watch screen's flashing at me at night.
Hopefully this can get added a feature at some point, any idea where to submit feature requests?
Best Answer07-03-2019 10:27
07-03-2019 10:27
You can post the feature suggestion in Feature Suggestions forum.
