03-07-2018 09:50
03-07-2018 09:50
Is it possible to disable the double tap wake-up function on Ionic?
It's really annoing, especially when I'm doing my boxing sessions and my screen keeps turning on all the time which results in random workout pauses during my workout. Yes, punching will wake up the screen just like taping on it.
Thanks
Best Answer03-07-2018 10:24 - edited 03-07-2018 10:31
I don't believe double tapping is your problem. Your problem is Screen Wake and it can be turned off by swiping right on your tracker and setting Screen Wake as you desire. It would probably be a good idea to then sync your tracker although I think this particular setting will probably take effect without a sync.
In any event, double tapping waking the screen can not be turned off.
Best Answer03-07-2018 11:07
03-07-2018 11:07
@SunsetRunnerwrote:I don't believe double tapping is your problem. Your problem is Screen Wake and it can be turned off by swiping right on your tracker and setting Screen Wake as you desire. It would probably be a good idea to then sync your tracker although I think this particular setting will probably take effect without a sync.
I always turn my screen wake-up to Manual but the screen steel keeps coming on as I'm punching.
Best Answer03-07-2018 11:10
03-07-2018 11:10
I don't know what else you can do then.
Best Answer03-08-2018 00:45
03-08-2018 00:45
@SunsetRunnerwrote:I don't know what else you can do then.
Probably nothing as there is no possibility to disable double tap wake-up function.
