03-28-2019
17:53
15:50
SilviaFitbit
03-28-2019
17:53
15:50
SilviaFitbit
How do I monitor an upper/lower exercycle
Best Answer03-29-2019 15:49
03-29-2019 15:49
A warm welcome to the Community @n2n! You can track this type of exercises using the option "workout". When you finish the exercise it will show you: duration, average heart rate, max heart rate and calories burned.
Best Answer03-29-2019 17:22
03-29-2019 17:22
Would that be something like a Bowflex? That's a cross between a stairclimber and an elliptical. I usually use the elliptical setting. Would Workout be more accurate?
Best Answer03-29-2019 17:52
03-29-2019 17:52
Best Answer03-30-2019 06:22
03-30-2019 06:22
@n2n What brand/model exercycle do you use? It sounds like elliptical is a good choice -- the movements sound like elliptical, but seated.
Laurie | Maryland
Best Answer03-30-2019 08:12
03-30-2019 08:12
Best Answer04-01-2019 12:44 - edited 04-01-2019 12:49
Hey everyone! Great to see everyone is sharing tips, sorry for the delay in my reply.
Great to see you around @Purrstachio! In this case, since you're moving your arms and legs the best exercise to track it would be elliptical.
Thanks for your input @LZeeW! I appreciate that you shared the exercycle that you're using, it would be better if you use elliptical if you're moving your arms and legs.
You can also post your idea in our Feature Suggestion board, so this exercise can be an option in the future.
Keep me posted! Don't forget to share your results.
