11-29-2017 01:44
11-29-2017 01:44
Very silly question here.
How do I tell if my ionic is still connected to phone? Sometimes I see blinking or solid fan, sometimes green, at times grey.
It is very obvious with most other apps. There is no indication on watch if it gets disconnected from phone as well.
Best Answer11-29-2017 07:34
11-29-2017 07:34
@ruriimasu, on the app the small communications link symbol above the battery is gray if the tracker is not connected, it is flashing green if it is trying to connect, and it is solid green if it is connected. Is that what you are asking?
11-29-2017 07:34
Best Answer11-29-2017 17:29
11-29-2017 17:29
@USAF-Larry Yes. That is exactly what I needed to know. Thanks mate! 😃
Best Answer02-14-2020 23:03
02-14-2020 23:03
Nothing showing above the batterie
