03-18-2018
13:38
06:08
JuanJoFitbit
03-18-2018
13:38
06:08
JuanJoFitbit
My son locked my ionic and it tells me on the watch to "Unlock with your phone" I can't find anywhere on the ionic app to unlock the watch. Please help.
02-18-2021
11:49
08:19
02-18-2021
11:49
08:19
Hello everyone, thanks for your participation in the Community.
Thanks to all for the efforts to resolve the issue, sharing the solutions and steps you've tried. I understand that this can be very frustrating, your feedback and comments are greatly appreciated.
For the ones that keep having problems, please follow the steps in this help article: How do I unlock my Fitbit device with my phone?
If your device is no longer paired to your Fitbit account, you can try a solution shared by a user in this post.
I am going to close this thread, but if you continue experiencing this difficulty, please contact our Support team or start a new topic.
Have a nice day.
03-18-2018 14:08
03-18-2018 14:08
@Pauloc1973wrote:My son locked my ionic and it tells me on the watch to "Unlock with your phone" I can't find anywhere on the ionic app to unlock the watch. Please help
So, I'm guessing your son "DEVICE LOCKED" your Ionic, as that is the only lock I am aware of. If this is what he did and you do NOT know the code he used, I would recommend you contact Fitbit Customer Service at (877) 623-4997, as the fix can be in-depth.
Hope this helped and keep on STEPPING!
Gunny | Richmond, VA (USA)
Ionic Adidas Edition, Versa Special Edition, Aria 2 & Flyer | iPhone & Windows 10
Take a look at the Fitbit Help site for further Assistance & Information.
03-18-2018
14:39
09:58
SilviaFitbit
03-18-2018
14:39
09:58
SilviaFitbit
Thank you for your help
Moderator edit: Removed personal information
03-19-2018 09:39 - last edited on 08-18-2019 14:02 by LiliyaFitbit
So this may also help you:
So, If you enter an incorrect PIN code 10 times, you're prompted to unlock your Fitbit watch with your paired phone.
To unlock your watch with your phone:
Note that after you reset your PIN code, you must add your cards to Fitbit Pay as if you were setting it up for the first time.
If the steps above don't work, please turn off everything that is Bluetooth enabled. Tablets, PC, other phones. Wireless headphones hanging around - power off. You don't want any stray 'signals' effecting this process. Then, remove your Ionic from your phone.
This was provided by Moderator @MarreFitbit
Hope this additional info helps!
05-04-2018 02:06
05-04-2018 02:06
Just had the same issue. I had charged the phone and taken it off. It asked for my pin which I entered correctly and then gave me the “unlock with your phone” message. I had not incorrectly entered it 10 times. Anyway I followed the steps as outlined, it takes a new pin, asks for it again, says “configuring tracker” then asks me to enter the pin but does not wait for me to type anything. It then says “Change pin failed”
Now what?
06-22-2018 06:54
06-22-2018 06:54
Did anyone ever get back to you? Or did you solve this issue? As I am having the same problem
07-27-2018 18:40
07-27-2018 18:40
same problem here seems to be a bug in the software. I have not seen a response from Fitbit as why this keeps happening.
07-28-2018 10:00
07-28-2018 10:00
Hey there @PAR3-! We've seen this type of issue regarding the 4 digit PIN that you can put on your tracker. However, this usually happens when the PIN has been entered incorrectly 10 times.
You can resolve it by doing this procedure:
Hope this helps! Keep me posted.
07-28-2018 16:02
07-28-2018 16:02
yes I understand how the system is suppose to work however in both case where this has happened to me I did not enter my unlock code 10 times. I had removed the watch while taking a shower and when I went to put it back on the message unlock the watch with my phone was being displayed. This indicates to me some type of a software bug not an user error.
07-30-2018 04:03
07-30-2018 04:03
I am having the exact same problem and the recommended solution does not work. After adding the device again, it still says 'Unlock with Your Phone' and if I go into the account in the app and try device lock it says 'failed to reset pin' then 'Blocked!'
Please help
08-02-2018 17:21
08-02-2018 17:21
Thanks for getting back @PAR3-! I appreciate that you've shared your experience with the Community. Your feedback is appreciated as this helps us to continue improving our service.
Hey there @pureoctain! It's pretty weird that the recommended troubleshoot isn't working. I would like you to restart your Ionic and log out from your account and then force quit the app. After this, please try doing the process again.
08-10-2018 18:55
08-10-2018 18:55
Iam having the same problem my Ionic all or a sudden came up with use Phone to unlock. I have tried the suggested fix still no solution, this appears to be a widespread problem. What is Fitbit doing to rectify?
08-17-2018 06:49
08-17-2018 06:49
This worked for me to fix the problem. I also turned Bluetooth off and on for my phone at the same time. I think my phone and watch were having connectivity issues which prevented me from resetting the PIN as normal.
08-17-2018 19:24
08-17-2018 19:24
08-22-2018 04:39
08-22-2018 04:39
Ionic displays ‘unlock with your phone’ when trying to do this in the app it prompts to change pin, this continues to fail and when previous pin is entered this also fails and comes up with a message that an ‘unexpected error occurred, please try again later’ every time. Very frustrating....
09-04-2018 20:23
09-04-2018 20:23
Hello ljy123
Has anyone sent you any instructions on how to fix the problem I’ve been having the same problem and can’t find a solution.
09-06-2018 05:26
09-06-2018 05:26
09-06-2018 17:41
09-06-2018 17:41
So, this is a huge ongoing problem. The solve isn't working for me either. I got this message after taking mine off of the charger yesterday
09-28-2018 05:02
09-28-2018 05:02
It didn't work with my ionic. I had to login to fitbit.com and removed the fitbit pay from settings and then I have pressed the three bottons together for a couple of seconds until the main page is shown, then synced it with the app. Now it's working but no wallet.
I dont think I will use it again full of bug! No proper solution!
09-28-2018 06:25
09-28-2018 06:25
