12-11-2017
03:56
04:55
12-11-2017
03:56
04:55
My Ionic do not Synchronisation with my cell phone.
it is like a lottery
my cellphone Huawei Mate 10 Pro
anyone an idea? Solution?
Thanks
Best Answer12-11-2017 04:58 - edited 05-19-2025 10:20
Hey there @SunsetRunner, it's nice to see you around the forums! The reason why your Mate 10 Pro is not syncing is due to this phone is not yet a compatible device with the Fitbit app. This means that our Android team has not yet tested it for compatibility and added it to the list what means that we don't have a estimated date on when it will be added. If the device supports BLE (AKA Bluetooth 4.0), I recommend giving the setup flow a try to see if you can successfully connect your tracker.
If setup does not work, I recommend setting up and syncing via a device listed as supported or using a Windows 10/Mac computer with integrated Bluetooth 4.0 running the Fitbit Software. Our Android team is always working to test and add more Android devices to the supported devices list, so keep an eye open for updates!
My sister owns a Huawei which is not yet a supported device, but she has tried the following (which I think won't hurt if you try that as well):
1. Your phone must not be set to "visibile for other devices"
2. Your phone must not be "searching for other devices"
If either of these two things are active, the Fitbit cannot connect.
In other words, you have to set it to invisble, and you have to click the stop button if it is searching for devices. So, bluetooth should be on, but not doing anything at all in the bluethooth menu. Then force quit the Fitbit app and it'll sync. At least it has done with my sister's phone for over a month or so.
I will also make sure to update you in this thread when the Huawei Mate 10 Pro is added to the supported devices list. ![]()
12-11-2017
05:38
05:41
12-11-2017
05:38
05:41
sorry, but i buy a expensive Fittracker and it do not work BT.
BIGGEST **ahem**
Moderator edit: removed personal information
12-11-2017 05:40
12-11-2017 05:40
Best Answer12-11-2017 05:57
12-11-2017 05:57
Best Answer12-11-2017 10:25
12-11-2017 10:25
Best Answer12-11-2017 11:20
12-11-2017 11:20
I'm having the same issue with my Mate 10 Pro and Ionic.
I love the watch, and the phone...but come on fitbit...one out of 10 notifications come through...please fix this
Best Answer12-11-2017 11:25
12-11-2017 11:25
Best Answer12-11-2017 11:47
12-11-2017 11:47
I agree that this seems a bit odd, but hopefully we'll get support soon.
Atleast now I know there is an issue with the app, and not my phone/watch...I was about to send one of them in since it was not working...
Best Answer12-11-2017 12:25
12-11-2017 12:25
02-12-2018 08:02
02-12-2018 08:02
I also experience the same problem. In order to keep them cope with the problem directly, I keep posting in their facebook page. maybe it's a good method to warn other android users
02-12-2018 08:16
02-12-2018 08:16
It's ridiculous how long this has been an issue...
