02-15-2019 19:50
02-15-2019 19:50
Need this for when I take vitals on patients. I need my screen to not sleep. Is there a setting I can change. I just got my iconic
02-15-2019 21:22
02-15-2019 21:22
Welcome to the forums!
Please go vote and comment here. It much needed
Hope to see you around the forums! Join in on the discussions forums!
Wendy | CA | Moto G6 Android
02-16-2019 05:35
02-16-2019 05:35
Only certain clockfaces allow you to do this (because it impacts battery life). If you search clockfaces for “always on” it will bring some up. Timebomb and Nothing Special are a couple of examples (you have to enable “always on” in the settings). RedStats is one of the faces that allows you to enable “always on” by double tapping the screen.
02-16-2019 07:20
02-16-2019 07:20
I would read the post by @MarreFitbit in the thread that @WendyB suggested, you might find something of interest there.
one cruise ship at a time!02-16-2019 14:02 - edited 02-17-2019 03:21
Yes @DramaQueenDiva 60 seconds should be long enough to start on.
Fitbit designed their Chronograph face to include the several functions that the medical personal have requested.
By tapping the lower right button you will activate the always on stopwatch that has both large analog and digital read outs
02-16-2019 14:17
02-16-2019 14:17
When I doh this it only brings up my alarm
02-16-2019 14:23
02-16-2019 14:23
Hello, I am doing this and it only. Rings up my alarms. I don’t see the setting
02-16-2019 15:30 - edited 02-16-2019 15:37
@Lupeh Push the LH button and swipe RH to LH until Settings, tap that, and then tap "Display Awake" and tap until you set the maximum.... then push LH button.
If you need to close the screen view while examining a patient just put your palm over the screen of the watch or push under you other wrist. There is a sensor there to help conserve battery.
I get about 6 days between charges wearing 24/7 with Workouts and NO GPS.. about 0.5%/hr between charges.. so you can monitor that while at work by swiping up from the clock face..
Let's know what you think..
@Lupeh wrote:Hello, I am doing this and it only. Rings up my alarms. I don’t see the setting
02-16-2019 15:42
