01-01-2019
10:05
11:59
AndreaFitbit
01-01-2019
10:05
11:59
AndreaFitbit
I had trouble syncing, so i did a factory reset. now i can't sync using my android phone or my laptop. what should i do next? PS: i restarted my devices and bluetooth with no success.
Best Answer01-01-2019 14:24
01-01-2019 14:24
When you do a factory reset it essentially becomes a new device to the apps. Here are the steps you need to take:
1. go to the phone app and delete Ionic from your account. On the phone app tap the icon on the upper right corner (the one that looks like a document).
2. On the settings page, tap on the Ionic tile.
3. On the Ionic settings page, tap on the trashcan icon on the upper right and remove it from your account.
4. Go to the phone's bluetooth settings and unlink the Ionic from the phone.
5. Go back to the phone app and then relink the Ionic to your account the same way you did when you first got it.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
Best Answer01-01-2019 15:54
01-01-2019 15:54
“what should i do next?”
Call the number below and explain your situation. They will walk you thru a bunch of troubleshooting and may get your device to work properly. If not -> if it falls under the Fitbit warranty they may replace it.
Your device should work properly. My first one was defective but my replacement is better so far. Let me know.
Best Answer01-01-2019 16:29
01-01-2019 16:29
what Number?
Best Answer01-01-2019 18:48
01-01-2019 18:48
The number in my sig.
Best Answer01-02-2019 12:05
01-02-2019 12:05
Welcome to the Fitbit Forums @Nu4FBi17! I´ll be glad to assist you syncing your Fitbit Ionic again. Were you able to resolve this issue?
To sync your device again, please set it up as a replacement device.
Thank you for your advise @wtksk8r and @Whistler888.
Let me know how it goes.
