10-03-2017
11:07
06:38
10-03-2017
11:07
06:38
If you have the same song in multiple playlists, does it use space for each instance or does each playlist reference the same file?
Best Answer11-13-2017 06:36 - edited 05-19-2025 09:59
Hey there @Vancelot, thanks for stopping by! If you copy multiple play lists that contain some of the same songs you will have duplicates.
When you make the playlist, it references the songs in their locations on the computer, without hard-coding the path, which would break things when synced to the Ionic. If you don't have two copies of a song on the computer, the Ionic will not make a separate copy of that song.
Hope this clarifies your question!
