04-20-2018 10:53 - last edited on 04-22-2018 06:31 by MarreFitbit
Yesterdays steps are not showing up but today's are. It says it has not synced since yesterday morning. Does Fitbit know how to program Bluetooth syncing? My old ChargeHR had trouble too but not this bad. Can't get the **ahem** thing to sync!
04-22-2018 06:36
04-22-2018 06:36
Hey there @GD11009, it's nice to see you around the Community Forums! If your device is paired to the Fitbit app, it syncs every time you open the app. If you turn on All-Day sync it also syncs periodically throughout the day. If you sync your device with a computer and Fitbit Connect, it syncs automatically every 15 to 30 minutes when the Fitbit device and computer are nearby, and the dongle is plugged in, if applicable.
To manually sync your device, with your device nearby, open the Fitbit app and find the picture of your device on the Fitbit app dashboard.
Are you still having issues when syncing your Fitbit Ionic? If so, I'd like you to make sure that your Fitbit Ionic is still connected to your Fitbit account. Maybe the tracker got unpaired and that's why it's not syncing? Also, check if the tracker is still appearing on the phone's Bluetooth settings.
Keep in mind that a syncing difficulties may be caused by a missing requirement. Check the following:
Depending your Android device, these tips might make syncing easier:
If those steps don't work, try these steps:
Also, check this helpful article for more details about this.
Try that out and let me know how it goes!
