07-12-2018 12:44
07-12-2018 12:44
Ok don't want to waste any more time on iconic so I'm asking does anyone have a solution or will I just return it. Battery goes from 100 to 0 in practically a few hrs, I've applied updates, I've unpaired and factory reset it, turned on and off phone, pressed all 3 buttons then releasing right but nothing seems to solve issue, I'm just wondering if it's a common problem with iconic am I better off just getting refund as will same issue arise again with next one
07-12-2018 13:06
07-12-2018 13:06
07-12-2018 13:06
Contact Customer Support.
Best Answer08-22-2018 19:30
08-22-2018 19:30
Battery life is poor. I have to recharge every 12 hours.
Best Answer08-22-2018 23:50
08-22-2018 23:50
Mine turned out to be faulty and store gave me a replacement right away!!! Your battery should last longer than that, return to store
