01-23-2018 09:03
01-23-2018 09:03
I thought this was fixed, but apparently not. Today I just finally got the update that was released to all, on 12-5. That was after I did a factory reset trying to get notifications working again. However, it didn't show immediately, it took several restarts before it would show, the restarts were needed because I couldn't get it to setup after the factory reset. Which, had I been thinking clearly, should have told me there was an update available, since that is how it was for the first few updates.
01-24-2018
17:29
09:53
01-24-2018
17:29
09:53
@SunsetRunner I hope you're doing well! Thanks for sharing your experience with us! It is very strange though! Keen to hear if other users have experienced the same?
Also, were you able to get it to update successfully?
Additionally, have you checked the Feature Suggestions Board? If you have any ideas for future features you would like to see on your Fitbit device, this is the best place for asking. Feel free to search for existing feature suggestions or add you own original one!
Keep me posted! ![]()
Best Answer01-25-2018 04:21
01-25-2018 04:21
I have yet to receive any update for my ionic. It is still on firmware 27.31.1.16.
Any advise?
Best Answer01-25-2018 04:49
01-25-2018 04:49
Yes, I was able to finally get the update. Except for one update, my Ionic has displayed this behavior since I received it (I was one of the original Ionic's shipped, since I was part of the original pre-order group).
Best Answer01-25-2018 04:50
01-25-2018 04:50
You are on the current firmware version.
03-22-2018 06:52
03-22-2018 06:52
My iconic will not accept this firmware update. I have; restarted my phone, the iconic, and tried turning the bluetooth on and off. Trying over wifi. Its fully charged. I have no clue why its doing this.
11:25
09:51
03-22-2018
11:25
09:51
@Girlpwr Welcome to the Fitbit family! Thanks for performing the update on Ionic and for trying those steps to resolve this. It's unfortunate to hear that it is not being accepted.
Are you still experiencing the same? I'd recommend trying these troubleshooting steps (once again if you already did some), in the order showing there.
Are you connected to your home's Wi-Fi network? It is better if you are. Also, try getting closer to the router while doing the update.
Hope this helps. Keep me posted! ![]()
Best Answer03-30-2018 11:50
03-30-2018 11:50
07:25
09:53
04-03-2018
07:25
09:53
@Girlpwr Thanks for your reply and for trying all of those troubleshooting steps in order to fix this.
I went ahead and created a case with customer support in your behalf for them to further assist you. Please keep an eye on your email inbox.
