01-08-2019 08:31
01-08-2019 08:31
Where do I find the on/off for continuous illumination or display on my Ionic device?
Have searched all settings but have not been successful in getting the device to continuously display or remain illuminated, i.e. have to manually tap or depress main button to see display!
01-08-2019 09:39
01-08-2019 09:39
There is no option for continuous display. That would kill the battery. You can turn "quick view" on and off to control whether the screen displays at the turn of the wrist or not.
01-08-2019 13:02
01-08-2019 13:02
Thanks for confirmation.
I have not come across a setting for "quik View" and rotating wrist does not cause illumination. Guidance welcome!
01-08-2019 13:10
01-08-2019 13:10
@Docster wrote:Thanks for confirmation.
Hey try pressing and holding the left button until it vibrates. Then tap Screen Wake. See if that does it. Should switch from Manual to Auto.
01-09-2019 05:41
01-09-2019 05:41
Got it.......thanks
01-16-2019 07:00
01-16-2019 07:00
Thanks again
