12-10-2018 16:17
12-10-2018 16:17
Ionic Battery Drain Stats
Using the Run Exercise Mode with Pause on
GPS on and connected full time
HRM on center screen
Distance on top
Elapsed time on bottom
Screen ON full time
Music playing full time
Bluetooth connected full time
77% Start for 2 Run exercises
To 59% = 18% over 36min = around 1/2% per min
To 48% = 11% over 20min = around 1/2% per min
So 29% over 56min = around 1/2% per min
So Ionic should last about 3hrs from a 100% full charge
Personally have needed to charge the Ionic every single day
As the GPS and Music and Screen Always ON drains the battery
Have tried the Screen Raise to view -> but like Always ON better
Is much easier to view when doing intervals and working out
Overall the Ionic has performed more consistently today
But there still are concerns about random crashing
Other concerns have been noted to Tech Support
This is a real world use general interest post using the Ionic as noted
If Screen Raise to view is used instead -> would expect less battery drain
These results are from an Ionic purchased last month on the .19 firmware
Hope this helps confirm battery drain concerns to Fitbit and others
Best Answer12-10-2018 20:49
12-10-2018 20:49
Hey Whistler,
I’m having the Ionic for a year and half and never had any issues.
I created a couple of day ago a post myself as well as the battery is completely drained in just over a day by only just wearing it and doing my daily thing. This is indeed since the last firmware update a couple of days before that. I used to be able to wear it for 5 to 6 days without recharging.
I only got a tip on how to charge your Fitbit from one of the moderators around here.
A whole lot of money to have it in the bin after a year and half
Best Answer12-10-2018 22:58
12-10-2018 22:58
Would suspect my “normal usage” is at or near maximum battery drain on the Ionic.
Understood from Tech Support that .24 firmware has only gone out to about 10% of users. So kinda are like beta testers before sending out to the masses. If yours is now .24 vs the previous .19 -> that may possibly explain your drop in battery life from 5-6 days down to just over a day. If yours is .19 then have no explanation other than to refer your concerns to Tech Support.
Because I often use the Ionic standalone -> with exercise GPS HRM Music and Screen ON near daily -> the battery drains very quickly. If it got 10 hrs that would be fantastic. But reality is the battery only lasts about 3 hrs.
So Fitbit should advertise this more accurately. Personally was expecting 10 hrs with GPS and everything functioning at max.
Maybe the advert should say the full battery charge with GPS -> ranges btwn 3-10 hrs depending on variables like HRM and playing Music and Screen ON full time. That would be more accurate and realistic for consumers. So am a bit let down having to charge the Ionic as much as I do. But it is what it is.
GPS unfortunately drains any device. Some faster than others. Sounds like your problem is a bit different however.
Best Answer12-11-2018 17:29
12-11-2018 17:29
It's great to see you around @Whistler888. Thanks for sharing your experience. I appreciate the time that you took to share all those details and letting other users know about the Ionic's battery while using all these features. I totally understand that you're fully enjoying your Ionic as you're always using the GPS and music playing. If at any point, you would like to save some battery, you may want to check this article Can I improve my Fitbit device's battery life?.
Hey there @SunsetRunner. I'm glad to hear that you're already troubleshooting this with a Moderator. We're here to assist you and help you solving any issue that you might be experiencing.
12-11-2018 21:56
12-11-2018 21:56
“It's great to see you around @Whistler888. Thanks for sharing your experience.”
Thanks for your comments Silvia. For me -> GPS and music go hand in hand whenever outdoors. Before used my phone with music and an upload to Strava. Now use my Ionic with music -> and the Fitbit link to Strava. Either method goes to Strava so am happy about that. Having Strava integrated in some way was a priority in my Ionic purchase decision.
Just got back in and can provide some more battery stats for those interested. Especially those that like longer timespan distance runs like marathons etc.
Distance on top
** Screen Raise to View **
77% Start for 1 Run exercise
To 52% = 25% over 1.5hrs
So Ionic should last about 6hrs from a 100% full charge
Or about “twice as long” vs with Screen ON full time
For me this battery life would suffice for most exercises
This info should help answer GPS battery drain queries
