06-11-2020 22:50
06-11-2020 22:50
I purchased the Ionic Fitbit and Skullcandy Sesh Evo wireless headphones. When I attempt to pair them (settings, Bluetooth, +audio device), the watch recognizes the headphones, but I always reach a “connection failed” screen.
I have tried all suggestions already provided in other threads: restarted both devices, disconnected them from other Bluetooth connections, gone to the Skullcandy website for pairing tips, etc. Both the watch and the headphones will pair with my iPhone, just not with each other (and yes, I’ve tried pairing them with my phone’s Bluetooth turned on and off).
06-16-2020 18:12
06-16-2020 18:12
@Run4f00d Thanks for getting back. I appreciate that you mentioned you were able to connect Apple AirPods to your Ionic.
We’re aware of it, but may not be able to provide a fix in the immediate future. We'll continue to monitor the situation, and keep our team informed of the impact to you and other customers. We understand that this isn't the resolution you're hoping for, but rest assured we're always working to improve our products.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
I'll be around if you have any additional questions.
06-12-2020 07:31
06-12-2020 07:31
@Run4f00d A warm welcome to the Community. Thanks for the troubleshooting tried prior to posting.
I appreciate the detailed information shared and the research done. I would like you to try putting your device on the same wrist of the receiver of the headphones. After this, follow this procedure to pair them:
> Bluetooth.
When pairing is complete, a check mark appears on the screen
Let me know the outcome. I'll be around if you have any additional questions.
06-12-2020 09:54
06-12-2020 09:54
06-12-2020 15:43
06-12-2020 15:43
My friend has an Apple Watch and Apple AirPods, so we tested out a couple of things. My Skullcandy Sesh Evo earbuds can pair with her Apple Watch, and her Apple AirPods can pair with my Fitbit Ionic. So why can’t my Skullcandy earbuds connect to my Fitbit? Please, just be honest with me: are Skullcandy earbuds & Fitbits not compatible?
06-16-2020 18:12
06-16-2020 18:12
11-13-2020 01:22
11-13-2020 01:22
are we any closer to getting this fixed, as the only reason i bought the fit bit in the first place, was to be able to exercise without my phone and still listen to music.
12-12-2020 15:02
12-12-2020 15:02
I’m having the same issues with the same headphones! Any update?? Wondering if the headphones are already connected to other Bluetooth devices preventing a new connection??
12-25-2020 15:41
12-25-2020 15:41
I just received the Versa 2 and Skullcandy Wireless Sesh Evo earbuds. I am getting the same Connection Failed as the others on this thread. I need to know if this is fixable and hope that I can return a gift (if not fixable) I have no receipt for as the buyer was told these earbuds would work with the Versa 2.
12-25-2020 20:52
12-25-2020 20:52
12-28-2020 05:42
12-28-2020 05:42
That's sucks! I bought these headphones specifically to listen to music on my Fitbit. No receipt so can't return. Bummer
04-26-2021
01:57
15:01
EdsonFitbit
04-26-2021
01:57
15:01
EdsonFitbit
I'm having the same problem. Support says they are working on it. I have my doubts. Fitbit will make me pay to return a product that doesn't do as they claim it does - that is just wrong.
What kind did you buy? I can't get Fitbit to tell me which ones work.
You wrote this over 9 months ago. Does this mean it's not going to be fixed? Can you provide us with a list of earbuds that do work with your products? I can't understand why you continue to advertise a feature that doesn't work. Like others, music is the main reason I went for the more expensive Smart Watch. And then, because of your false advertising, I have to pay to return your faulty product.
Moderator edit: format
08-02-2021 09:43
08-02-2021 09:43
Has this been resolved? I just bought skullcandy earphones and they pair fine with all my other devices but not my brand new Versa 2. Looking for answers as the store I purchased from promised that these would work with my device.
09-21-2021 12:07
09-21-2021 12:07
Same thing. Fitbit Sense and Sesh Evo won't pair. Both will pair with other products. They just won't pair with each other.
10-29-2021 07:34
10-29-2021 07:34
Good Mornign Silvia. Just wanted to see if Software Engineers are still working on the combability issue? Which does seem to be the issue. I got these SkullCandy Ear buds thinking they should connect to my ionic. I had previous Plantronics headphones that had connected. But, yeah, I get the same connection failed issue.
12-25-2021
11:02
15:05
EdsonFitbit
12-25-2021
11:02
15:05
EdsonFitbit
Does not work at all!
Same issue - still no solution from Fitbit. I’m getting slightly
Same. They pair fine with the iPhone and everything else, the Versa 3 won’t let them….
01-20-2022 15:35
01-20-2022 15:35
Hello everybody.
Our team is constantly working to improve our products and services. Your feedback is highly appreciated.
At the moment, there is no information about this topic. If there is any update available, it should be communicated as soon as possible.
Have a nice day.
04-18-2022 14:10
04-18-2022 14:10
Hello,
Since you can't seem to get this issue resolved could you possibly suggest WHICH bluetooth earbuds WILL pair with the Sense?! It's not as if SkullCandy is an "off brand". I have the Sesh earbuds mentioned above in a prior post. This is so infuriating!
04-19-2022 17:51
04-19-2022 17:51
I tried to get an answer for which earbuds worked with the Versa 2. According to Fitbit, their developers have been working on the answer for years. Apparently they are the most inept developers in the world along with Fitbit not bothering to test their product. So I did what Fitbit probably hoped I would do, and quit asking them for a solution.
Doing my own testing, I found the only earbuds that worked with the Versa were Apple AirPods. So you might want to try those, Apple apparently has good developers and quality control.
04-19-2022 18:54
04-19-2022 18:54
