10-09-2017
02:42
20:01
RicardoFitbit
10-09-2017
02:42
20:01
RicardoFitbit
Hello everyone, I wanted to understand if anyone else is experiencing a very bad quality when it comes to music streaming via bluetooth from the watch.
I know that streaming over bluetooth implies a loss of quality, but there is a significant difference when compared to the same song (mp3 320kbps) played via bluetooth from my pc or phone to the same pair of bluetooth headphones, so I'm comparing two different bluetooth streams.
Now, given also the already widely discussed sync issues of the ionic, this makes me think that the whole thing might be caused by hardware problems in the bluetooth module, that leads to a high packet loss hence the poor streaming quality and the sync issues.
Is anyone else experiencing that? Does any fitbit engineer/developer have a more plausible technical explanation for this behaviour?
It's frustrating because the watch is overall amazing and it would be an hassle to return it, mostly because I wouldn't feel like starting a russian roulette of replacing it until I find a completely functioning one.
Moderator Edit: Subject for clarity
05-10-2018 22:36
05-10-2018 22:36
05-15-2018 13:42
05-15-2018 13:42
Same issue here. Very low volume first couple of runs, then was deafened the next time I connected my AirPods. Tonight couldn’t get the volume below whisper level. Pretty useless. Also keep disconnecting, even though both the Versa and AirPods are fully charged. Frustrating, and as you say, on s fantastic piece of kit!
07-24-2018 08:53
07-24-2018 08:53
I've just got my Ionic, my wife got a Versa at the same time. I have a pair of Audiofly Bluetooth headphones that run Bluetooth v4.2. They suffer the poor quality issue on both the Ionic and Versa. It's as if the music is being streamed/played too fast (hence the pitch shift) and then it chops out for a fraction of a second to re-sync. The Audiofly headphones work perfectly with my Nexus 5x phone.
My wife has a pair of BlueAnt headphones that run Bluetooth v4.1. These work fine on both the Ionic and the Versa.
I understand that both the Ionic and Versa run Bluetooth v4.0 LE. It's my theory that on Fitbit devices, this works fine with headphones running Bluetooth v4.1 but not Bluetooth v4.2.
Here's to hoping that Fitbit can offer a software update to fix this.
07-25-2018 18:41
07-25-2018 18:41
A bit of further info from me. I just tried my Ionic with a friends Bose QuietComfort 35 II, which run Bluetooth v4.1, I believe. Absolutely no issue, perfect quality. This further adds to my theory (still obviously just a theory) that the issue is compatibility between Fitbit's bluetooth v4.0 LE and bluetooth v4.2 headphones. I'm going to try and get my hands on another set of bluetooth headphones running v4.2 and see whether they also have the streaming/quality issue.
08-01-2018
10:23
06:15
JuanJoFitbit
08-01-2018
10:23
06:15
JuanJoFitbit
Yes. At first I thought it was the Flyer headphones and I returned them. Then I started using them with my other Bluetooth headphones and the connection was even worse. I can’t listen to music at all while running. It is beyond annoying. I might return the watch because of it
Yes, horrendous. Cuts in and out and sounds like it’s skipping. Really not happy. That was the whole point of purchasing.
Moderator edit: merged reply
08-01-2018 11:12
08-01-2018 11:12
08-29-2018 16:16
08-29-2018 16:16
Link no longer works.
09-04-2018 12:12
09-04-2018 12:12
I agree. I am so frustrated I paid so much for this and I still have to bring an ipod with me. False advertising big time
09-04-2018 12:22
09-04-2018 12:22
10-15-2018
19:35
06:16
JuanJoFitbit
10-15-2018
19:35
06:16
JuanJoFitbit
Seriously I went to one of those resale refurbished stores and got a pair of biconic wireless earphones Bluetooth version 4.2 and they work perfectly I had Altec Lansing that were 4.2 did not work these are the literal Wireless just in earbuds and they work flawlessly.
Bluetooth version 4.2 biconic literal no wire wireless headphones work great head version 4.2 Altec Lansing didn't work because they had the wire on it.
Moderator edit: merged replies
10-16-2018 02:30
10-16-2018 02:30
Just pick up a cheap pair of wireless Bluetooth earphones. Sorted!
10-19-2018
11:35
08:17
10-19-2018
11:35
08:17
Hey everyone! I apologize for the delay in my reply. I appreciate the details that you've mentioned as well for the troubleshoot that each of you have performed.
I would like you to confirm that you've followed this procedure to use music control. If you're having any issue with it, please check this article for some troubleshoot that can help in this type of cases Why can't I control music with my Fitbit device?.
Additionally, you may want to check this article for more information while using Bluetooth Is the Fitbit app interfering with other Bluetooth devices?.
11-15-2018 07:30
11-15-2018 07:30
Thats my whole issue, it connects no problem if I stand in the corner of the gym and don't move I might be able to listen to a song but the minute I move my arm, go for a run etc it gets scratchy, skips like a damaged record. so frustrating I can barely stand it. I am about to switch to Iphone witch I hate just so I can have a tracker that works.
Also seriously the way you have to add music is ridiculous and takes forever
11-16-2018
16:19
08:16
11-16-2018
16:19
08:16
Great to see you around @motoxrunner. Thank you so much for your feedback on the music process. Fitbit is always trying to improve the customer experience.
I would like you to confirm that you've followed this procedure to control music with your Fitbit device?. If you've have tried it but you're still getting inconveniences with it, try these steps Why can't I control music with my Fitbit device?.
Also, here's the other help articles that can help you if you're downloading music to your watch and this one if you can't download music to your Ionic.
I'll be around if you have any other question.
11-16-2018 16:31
11-16-2018 16:31
04-25-2019 12:14
04-25-2019 12:14
Actually my original issue was just terrible music quality. Like 96kb/S compressed mp3 from 1992 level quality. I’ve always been able to control volume independent of music playing just fine, even used it to alter volume when playing via aux to my car a few times, or skip tracks.
04-25-2019 17:08
04-25-2019 17:08
I have resolved my issue with listening to music via my fitbit ionic by buying the fitbit flyer earbuds. The music is clear and audible. I'm happy I can now listen to my music while working out. I tried 3 other types of earbuds before I decided to bit the bullet and just get the fitbit flyers.
04-28-2019
19:57
08:16
04-28-2019
19:57
08:16
Hello! Welcome back @Codsworthy and @Mini-12, I'm glad to see you again participating in our forums. Let me give a hand with your inquiries.
@Codsworthy I would like to let you know that Fitbit is always striving to improve our customer's Fitbit experience with our products and services. We appreciate all of the input we receive from our customers as such information help us to evaluate our procedures for future cases.
@Mini-12 Thank you for taking the time to share your experience with your Ionic watch and our Fitbit Flyers, I'm sure that other users will find your post helpful. Hope that you're enjoying your Flyers the same way we do.
I'll be around if you need anything else guys.
05-05-2019 20:17
05-05-2019 20:17
05-06-2019 00:09
05-06-2019 00:09
