07-30-2018 07:07
07-30-2018 07:07
for several days my FITBIT Ionic doesn't register active minutes. Even when my heartrate is in the different zones for longer periods of time.
And when i start a run or walk my fitbit wouldn't connect the gps, since 2 months in the Netherlands, but when i was in Germany for Holiday it connected instantly, back home again it doesn't connect to de gps.
I've already done an reset of my FITBIT.
Can some one help me.
Best Answer07-30-2018 08:20
07-30-2018 08:20
Hello @BroedersM and Welcome! Sorry to hear your having issues with your Ionic. As an Ionic owner the Reset usually fixes things right up. I see in your post that you have already completed that and would recommend you do the RESET "3" consecutive times. That hopefully will clear up everything, but if not, you may need to do a Factory Reset, which will bring your Ionic back to when you first received it. Before we do that however, I would recommend the "3" consecutive RESETS.. Please post back and advise.
Thanks and Keep on STEPPING!
Gunny | Richmond, VA (USA)
Ionic Adidas Edition, Versa Special Edition, Aria 2 & Flyer | iPhone & Windows 10
Take a look at the Fitbit Help site for further Assistance & Information.
Best Answer08-04-2018 00:24
08-04-2018 00:24
Hello @GySgt_Seidell thank you for the advice. For now the active minutes works but only a small bit. I'll keep an eye on it so when it doesn't in prove I will put up a new message.
For the GPS I have not yet had the time to test. So for that I will respond later.
