02-04-2019
13:38
08:34
SantiR
02-04-2019
13:38
08:34
SantiR
I’ve noticed over the last week or so my battery is draining very quickly I have dove a factory reset & hard reset dropped 10% in half an hour is this Normal notifications are off & watch is set to manual
I use it a lot at the gym for music & log exercise ? 😊
Moderator Edit: Updated Subject for Clarity
Best Answer02-05-2019 08:34
02-05-2019 08:34
@Chesh68 Welcome to the Fitbit forums! Thanks for taking the time to share the experience you are having with Ionic's battery power. Thanks for trying those steps in order to sort this out and for sharing those details.
There are some features that may be draining your battery faster such as music and using the Exercise app and GPS too. Please check the different features that drain battery fast here. You will find tips to improve the battery tips.
Check that out and let me know how it goes! ![]()
Best Answer02-12-2019 04:42
02-12-2019 04:42
My Ionic went into meltdown mode you are kindly sending me a replacement excellent service again from Fitbit 😊
